Simpson County
carlzzz69
Anyone have the ID's for Simpson County? I have the frequencies.....
INDY72
Indianapolis, IN
LCN
If you have them in the proper LCN order and your scanner can trunk track LTR then you should be getting id's all day. As I only have a PRO-2052, and a 30 chan conventional scanner I cant trunktrack LTR.
carlzzz69
Thanks for the reply.... I didn't understand LTR when I posted (newbie to trunked). I can't do LTR with Pro95.... I scan w/conventional settings just fine.
INDY72
Indianapolis, IN
LTR and Conventional Scanner
So true, you can listen to most LTR with no issues, and can easily tell by the convos what your listening to. The only annoying LTR systemns to listyen to are the ones like in use in Natchez. When monitoring these you have to deal with the every second or so ZZZZT sound on the chans. If you live near eneough you can just program the base chans and listen to both sides of comvos without the ZZZZT. But if your far enough away that the mobile side cant be heard then just program the repeaters with no, I repeat no delay and you can monitor without too bad an issue. If you put in delays it will lock on just one of the chans and you may miss calls. As for digital LTR as with EDACS PROVoice, there is no scanner that can do them yet.
lfdmedic5
Pearl, MS
simpson co ltr ids
simpson so -1050
magee pd-1150
i have pro-2069 and that is the ids it shows for simpson co.
if you need any more frequencies contact me. i live in simpson co
carlzzz69
If teh local pd's don't share the same freqs, I would like to get them for Magee, Mendenhall, and maybe Florence. I rarely hear anything from them on the Simpson freqs in the database.......
AC0RV
Park Hills, MO
The Simpson system
Does anyone who how to convert them so that they can read on the PRO-92 and Pro-2067 scanners.
Any help would be appreciated a lot.
Thanks a million.
Dave F
lfdmedic5
Pearl, MS
carl
magee pd and simpson so our on the same system. and florence pd is on rankin co system in the database the id for florence is on
the list
Rick54
Mississippi
Simpson County ID's
The ID's for the Simpson County system are as follows (but look for changes later in 2004)
Mendenhall PD 0-01-075
Magee PD 0-01-150
S. O. 0-01-050
There are some others but I don't have them handy
Magee works off the South Tower,
Mendenhall works off the North Tower
The S. O can work off either tower
The towers are not linked
INDY72
Indianapolis, IN
Magee
Heard Magee on 155.0900 Last night, wish my scanner could track LTR.....
Rick54
Mississippi
155.090 is a MHP high band freq I think, the problem is the new Simpson freqs use the new 7.5mhz step and not many scanners will even go to the exact freq. what some people are doing is putting in a freq as close as they can to the exact freq and just hearing the bleed over(most scanners are very broad) The transmission you heard was actullay on 155.0925 most likely.
INDY72
Indianapolis, IN
true
I enter the freqs and my scanner automatically pops to the closest it can do. The newest scanners are at least friendly eneough to give us the full 12.5 steps.
Rick54
Mississippi
Another repeater has been added to the north tower of the Simpson County system. The Freq is 154.0325 but I don't think much will be heard there because there are only 2 talk groups using it and I don't know why it would every be used unless one of the 1st 2 failed
INDY72
Indianapolis, IN
Could possibly be for future usage by the EOC/VFD's???? And thus bring all county services online?
Rick54
Mississippi
Well not really, the VFD on this end of the county opted to remain conventonal, we just did not think it would be any advantage for us to get on the trunked system. For one thing the radio's cost a lot more, so the north end of the county VFD still operate on 154.205, Pinola operates on 154.325 and there is a conventional repeater on the south tower but I don't recall the freq.
lfdmedic5
Pearl, MS
simpson
does anyone know if station 7 fire dept in simpson is on a repeater or is it trunking
Rick54
Mississippi
Re: simpson
Station 7 is on the South Tower, they supposed to be on 155.6775 (I have heard them there) but for some reason I now hear the 10 second beacon on that channel as if it is now trunking, so Im not sure what the deal is there.
Rick54
Mississippi
Ok here goes, I show Magee FD on 151.055 with a DCS of 174. And I show Station 7 on 155.6775 with a DCS of 023. I hope this helps.
lfdmedic5
Pearl, MS
simpson co
does anyone how to get the pro 2067 to take the simpson co freq off the trs database. when i put them in it converts them to a 12.0 mhz step (i think) i think it needs to be a 7.5 step.
Rick54
Mississippi
I don't know which radio shack radios will do the 7.5 step, but I have a Uniden 785 it will also the 780 will. You would have to consult the manual to see if your radio will, RS manuals are on line if you don't have one.
