BCD396XT/BCD996XT: Simulcast FQ. not locking out?
KD0FEO
Wright County, MN
Cokato, MN
My control channel is 851.850 which comes in crystal clear, along with about 6 other frequencies. I have ONE frequency that when my radio calls upon it, it really struggles to decode and broadcast clearly. I've been watching the screen and have locked out that frequency in "Trunk Frequencies" in Freescan to no avail. I then deleted the problem frequency, and it's still calling upon it when the other signals are obviously closer and give better reception. I guess my question is how do I keep locked onto the close sites and have my radio ignore everything else? I'm on the outer edge of the coverage area, which has been great except for the one frequency.
hiegtx
Dallas, TX
The site in your county is Simulcast.
With a Simulcast site, there are multiple towers broadcasting the exact same talkgroup transmissions on the same frequency. As these transmit locations are at varying distances from you, the signals arrive out of sync, keeping the scanner from decoding them correctly.
The data stream from the control channel (851.850 is a control channel for the site covering your county) tells the scanner which voice channel to use. That's the case even when the specific voice channel frequency is not programmed in that site. So, deleting the frequency has no effect at all.
The full map (see the link just above the screenshot of the site) is somewhat misleading, since there are multiple licenses listed; some have sites in other counties, on different frequencies, which are not connected to your county.
If using an external antenna (such as one above your roof), you might be able to use a directional antenna, aimed at one specific transmit tower, to counteract the simulcast issues. If using the telescoping antenna that came with the scanner, you may find that placing something metallic, like a cookie sheet or baking pan, vertically, on one side or another of the scanner, might block the out of sync signals,
More on Simulcast in the Wiki.
Simulcast digital distortion - The RadioReference Wiki
KD0FEO
Wright County, MN
Cokato, MN
I have attempted using a cantenna, baking sheets, strainers, different antennas. The only thing that has worked well is I took an existing scanner antenna and did the math to about 3.3 inches 1/4 wave for 850mhz and cut it down to that. That is when the radio really started being responsive and got the best results. Where I used to live in Buffalo, there was no signal at all.. even with a 800mhz Yagi on the roof and in the attic.. Simulcast is really frustrating. It's hard to provide a feed and every so often get some traffic that is ineligible. It's hard to track that one frequency because it only happens every so often and I don't know how to lock onto it. I am fairly new to all of this and trying to learn but I'm starting to get confused.
tvengr
Well Known Member
Baltimore County, MD
If you attach your FreeSCAN programming file, I will check it for problems. You will need to right click on the file and Send to Compressed (zipped) folder to be able to attach it. Click on Attach files and Open the zipped folder. I agree that you may have simulcast issues.
tvengr
Well Known Member
Here you go @tvengr
I have your file. I see that you have Sherburne and Wright Counties setup as 2 different systems. If you scan both systems, you will be upcutting the audio on both. While scanning the Sherburne County system, you will miss the beginning of any traffic in Wright County. Likewise, while scanning the Wright County system, you will miss the beginning of any traffic in Sherburne County. Since both counties use the same site, you should have a single system. By doing so, you will immediately hear traffic in either county. You can select what you want to scan in either or both counties by placing talkgroups into groups and using group quick leys. I am in the process of creating my own file and will attach it when completed so you can see how it is done. I don't see any blatant errors in the existing file, but I will be making some changes which I believe may improve performance. In the meantime, please read the file I am attaching which will answer all of your questions about using quick keys.
  • Uniden Scanner Quick Key Instructions DMA.pdf
n1chu
Farmington, Connecticut
“ If you scan both systems, you will be upcutting the audio on both.”
Upcutting? I read your explanation of what you believe is going on but still haven’t understood what you mean by “upcutting”.
n1chu
A couple of suggestions you might try;
You don’t state what you are using as your feedline from the yagi mounted on the roof or in the attic. Frequencies at or above UHF need low loss coax such as Belden 9913 or equivalent, especially if your run is of any great length… and if you are on the fringe of the services you wish to receive in your area, which you say is a factor, it becomes even more critical. I run 50 ft. of Belden 9913 to my yagi mounted outside on my roof about 30-35 ft. up from the ground with a short pigtail of RG8 for flexibility on the scanner end. (9913 is a thick, stiff coax cable that doesn’t allow for tight bends. So I’ve added a more flexible short RG8 pigtail, the length is only as long as necessary, in my case just a couple of feet. At the time I bought the Belden 9913 there wasn’t much to choose from but I believe there are newer offerings that allow for flexibility, where my RG8 pigtail wouldn’t be necessary.)
I started out using the RG8 for my entire 50 ft. run, not realizing the need for the low loss coax when receiving 800 MHz frequencies and had horrible results! But once I swapped out the RG8 for the Belden 9913 I have greatly improved reception on all bands, especially the 450 and 700-800 MHz bands.
The other suggestion I have is to limit the simulcast sites you receive to only the strongest site for your location. In previous threads relating to simulcast systems where I’ve suggested this I’ve gotten feedback stating this is NOT a solution to the simulcast problem. And as I have never had issues with simulcast systems in my area, I’m not all that familiar with the simulcast issue. But I’ve limited the simulcast sites I monitor without issue at home, (while mobile I may be experiencing the simulcast issue but since I haven’t noticed it, it’s pretty much a moot point for me.)
I do not dispute other replies you have gotten or will get regarding simulcast. My knowledge of it is limited, never delving into it too deeply because it’s never been a problem for me… therefore, I yield to those better versed on the subject.
Hope this helps…
KD0FEO
Wright County, MN
Cokato, MN
I don't actively scan Sherburne, it's locked out and will be removing it. I don't have the Yagi anymore, I have a cheap magnet mount that I cut down to 3.3" which has helped. The antenna is inside stuck to the top of my pc tower, if I move it to the window or outside it reduces quality. I think the resistance of being inside kind of helps, just not for 851.175 which is the site giving me problems. When I actually get my antennas on the roof I will be using LMR 400 or 9913. This weekend I am going to experiment with antenna's and locations, when I originally set up the radio the conditions were good and signal strength was strong.. but it appears it fluctuates pretty heavy where I'm located. Best antenna I've used for portable was a Remtronix rubber ducky, they offer a BNC 90 degree model for base scanners.
tvengr
Well Known Member
Upcutting means clipping the beginning of the transmission. While scanning the Sherburne County system, you will not hear the beginning of a transmission on the Wright County system. It will cut into the middle of the transmission when the Wright County system begins scanning.
The reason moving the antenna near to the window or outside reduces quality is that the Sherburne/Wright County site is simulcast and you are suffering from simulcast distortion. You may not be able to receive the system at all using an outside antenna. The site consists of many towers, all transmitting on the same frequency at the same time. The signals all arrive at your scanner at slightly different times which degrades its ability to properly decode the control channel. By using a poorer antenna, you are reducing the number of towers received which will improve control channel decoding. Try turning on the attenuator. It may improve reception. The file I am working on has both the Sherburne and Wright County talkgroups in a single system using a single site. You will be to easily turn the groups with Sherburne County on and off using quick keys. The talkgroups for Sherburne County will still be available if something happens in the adjacent county and you want to monitor it. The only scanners specifically designed to receive simulcast systems are the Uniden SDS100 handheld and SDS200 base/mobile. The Unication G4 and G5 pagers also do an excellent job.
tvengr
Well Known Member
Here is your file. You can delete the present Sherburne County and Wright County systems on the scanner. The new file will replace both. Unlike a conventional system where the number of frequencies can slow down the scanning speed, the number of talkgroups in a trunked system has no effect on the scanning speed. You don't need to worry about the number of talkgroups in a trunked system as long as it doesn't exceed 500 per system which is the maximum for the BCD996XT. SD card scanners do not have that limit. Save the attached zipped file to your computer and extract. Open the extracted file with FreeSCAN and Upload Programming. I hope you took the time to read the quick key instruction file. Quick keys as follows:
SYSTEM QUICK KEY:
1. ARMER Sher/Wrght (Site)
GROUP QUICK KEYS:
1. Shrbrn DPW/Misc
2. Shrbrn Interop
3. Shrbrn Fire
3. Shrbrn Loc Fire
4. Shrbrn Sheriff
4. Shrbrn Local PD
5. Wright Pub Works
6. Wright Interop
7. Wright Fire/EMS
7. Wright Loc Fire
8. Wright Law
8. Wright Local PD
9. MN State Patrol
  • Sherburne_Wright FS.zip
KD0FEO
Wright County, MN
Cokato, MN
Ok, I loaded that up before work and have it running. Had to make a few modifications to the lockouts for broadcasting but the distortion is really starting to get to me. I may or may not have thrown my antenna and now having to use a paperclip. The radio needs to stay in this room because my computer and ham equipment are all in here, this is the reason I sold my first scanner.
tvengr
Well Known Member
You may notice a few changes. I turned off the AGC. The AGC action can increase distorted audio problems. I have only the control channel and alternate frequencies. programmed. They are all you need. All of the frequency information is carried on the control channel. I also changed the Audio Type for all of the talkgroups from Auto to Digital Only. The scanner does not need to decide if it is analog or digital and can begin decoding immediately. If you do not want Sherburne County, all you need to do, while scanning the system, is to quickly press FUNC and then 1, 2, 3, and 4 on the keypad. That will turn off the groups for Shelburne County.
smithken
Michigan
Have you tried no antenna at all. My 396XT receives my local simulcast system without an antenna.
wtp
Port Charlotte FL
you have to be kind of close to a tower for the no antenna thing to work.
i use that to find towers, or what is on them.
another thing is the old paper clip 'antenna'
or to look a bit better,
KD0FEO
Wright County, MN
Cokato, MN
Thanks everyone for the help, I've been messing with this for 5 days now trying to figure it out and I am literally exhausted. I thought I would give it a second chance in the new house but it's the same old problem. I've tried upstairs/downstairs/directional/paperclip/antenna on extension cable, outside on my roof holding my 996xt with an extension cord. I'm not looking to spend a fortune on scanning and don't want to give a crappy product/feed to the community. I'm tired of seeing full bars, excellent audio and in the same transmission drops to 2 bars and sounds like crap. Now I understand why Wright County hasn't had a feed, it's an absolute nightmare. Even the deputies complain about having to call in using their phones because of it. If I ever get this problem sorted I'm sure I will resume feeding but I can't constantly keep having to mess with it when I'm expected to be live.
n1chu
You can build attenuation boxes the hams use for their “Fox Hunts”, a fun exercise/activity using a handheld directional antenna to find a transmitter’s location using 3 receivers to triangulate… as the receivers get closer, they increase the attenuation of the frequency they are receiving to “narrow down” the direction the signal is coming from, and pinpoint the location of the “Fox”. One ham will go hide somewhere (the Fox) and three others will try to find the Foxe’s location. I haven’t seen any commercial offerings for these attenuation boxes but I haven’t been looking for them-they might exist.
With such a device, you could dial in the amount of attenuation and learn where the sweet spot is for your location, or if there even is a sweet spot. It’s not a foolproof method of learning if your type of antenna (less gain, no gain, no antenna at all) can make a difference but if you don’t have one of the radios (SDS100 or SDS200) built with simulcast considerations in mind, it might be helpful.
I still believe if simulcast is a problem (when using other scanners not designed to combat simulcast problems), programming simulcast systems should be done using only one site at a time, learning which site is strongest to your location, and attenuating that frequency to where it’s the only site the radio will hear, using squelch to eliminate other sites transmitting the on the same frequency at the same time. But I’ve received pushback on this method (they say it won’t work) and acknowledge there are others with a better understanding. To these “others” I offer my acceptance of their “take” on the matter, not wishing to get into a debate as to where my thinking has gone wrong because admittedly, I am no where near an expert and can not defend my point of view technically. So, please, do not accept this post as a challenge. I do not care to get into a give-and-take over it. Besides, it would probably be considered “hijacking” this thread which I believe is a violation on this board.
hiegtx
Dallas, TX
With one, occasional, situation, you cannot "program" simulcast issues away. The exception being those instances where using attenuation can reduce signal strength enough so that the scanner can ignore' the weaker, out of sync, transmissions from more distant transmitters and enable the radio to decode the stronger signal.
By definition, a 'Simulcast site' is one where there are multiple transmit towers that are part of the Simulcast site, all broadcasting the exact same radio traffic on one or more talkgroups are carried in the same frequency from each of the transmitters in the overall simulcast site. If you don't program the frequencies for the simulcast, then you will not receive that site. If you do, then the scanner has to deal with multiple signals, from various locations, using the same frequency & talkgroup radio traffic. As these signals originate from transmit towers at varying distances from your location, they arrive at different times, While the time differential may be minute, it is still enough to hamper the scanner's ability to receive & decode the traffic correctly.
I think one thing that can add to the problem for programming is that we tend to use the same name for two different items. This is a system in my area:
You see the first Site listed is the GMRS Simulcast Site.
But if you click on the site, to see its details, you'll see the term "Site" is used to mean something different:
In the case of the site details, we also see the term Site used to describe the fact that there are actually four locations where the same radio traffic is broadcast.
(Actually, according to the license there are more than four sites, as you can see below.)
Each of those listed locations transmits the exact same signals, on the same frequencies, as each of the others You can either program the site, and seal with the simulcast as best you can, or skip it & lose the radio traffic carried on them.
There are some locations (but not this system) where you have one large Simulcast site, but also others in the same county. But if you look at the details, these additional sites have many fewer assigned frequencies as does the main (simulcast) site. These are often 'fill-in' sites to ensure reception in areas not covered sufficiently by the main site. That is obvious because for the larger simulcast site, you may have 10, 12, or more frequencies in use, but these smaller sites have a handful, like 4 or five frequencies. There is no way that five frequencies can carry the same amount of traffic as the much larger 10 or more transmitters of the Simulcast. However, if that smaller (fewer frequencies) site carries all the radio traffic for your specific city, then you can use it, with the knowledge that you will not hear all of transmissions carried on the larger site.
GTR8000
NY/NJ Database Guy
BEE00
The correct terminology is "subsite" when describing one of the multiple physical transmitter locations that make up a simulcast cell. If people used the term subsite more often, there would be a lot less confusion.
The term "site" in the context of a simulcast cell is used to describe the virtual Site ID (Site #) that is used to reference the collection of subsites that make up the cell.
So in that regard, if someone says "trunked site", they can be referring to either a standalone site or a simulcast cell. If they say "trunked subsite", there is no mistaking that they're referring to one location of a simulcast cell.
KD0FEO
Wright County, MN
Cokato, MN
I moved the radio upstairs and using the driver element of a 4 element beam project antenna from when i was younger. It seems to have solved my problem. It's not pretty but works until I can find a good yagi.
  • Like
Reactions: wtp
