Single Channel DMR not receiving on BCD536HP
fdnyfish
Barnesville, PA
Im using the same FL on my SDS100 and BCD536HP.
I have a FL that is a single Freq DMR set up to my Openspot1 Hotspot.
When I have the hotspot TX, the SDS100 picks up the transmission right away, but the BCD536HP receives nothing.
I have tried this with ID Scanning and ID Searching.
I have both Unit ID's and Talkgroup ID's programmed in this system.
I did try to manually enter a freq on the 536, and set it for Digital Only and that picks up my Openspot1 when it transmits.
What am I doing wrong here?
tvengr
Well Known Member
Baltimore County, MD
Dumb question! Do you have the DMR upgrade on the 536? If you do, go to Settings > Upgrade > DMR > E. It will tell you if activated. If not, enter the key.
fdnyfish
Barnesville, PA
I have ID Search On, and I am seeing the the TGID on the 536 (I have about 700 TG's in my FL).
Is there a way to also see the UNIT ID on the screen? (I have 15,000 Unit ID's in my FL)
