sibbley
I'm having an issue with 1 single conventional frequency I monitor on my 436HP. The issue being a snapping noise. Almost sounds as if I have the priority set for 1 second on the radio and it's checking priority channel. I don't get this same noise on any other frequencies, or any other radios set to the frequency in question. I'd say this has been going on for a month or so.
I tried re-setting the scanner settings and adding all my favorites again from scratch. Still have the noise on that 1 frequency. It's as if there is a problem with the specific frequency, but the snapping noise is not present on other radios.
I thought I'd check and see if anyone else had a similar issue and found the problem. I'm stumped.
Thanks,
Thanks,
