Sirio gpe 27 5/8 base station antenna
Cdtompkins
Hello everyone, im new to the group and new to base station antennas. I just received the sirio antenna, I set it up as per instructions the best I could understand them.put it on a 2 ft pole to make adjusting easier and the swr is pegging the needle. Do i need to mount it on the 12 ft mast and recheck or what have I done wrong. Do I need to remove the radials. Im trying to talk on the 11 meter cb band. Thank you for any help.
Co-pilot
prcguy
Checking a CB base antenna on a 2ft mast above ground can show slightly different VSWR than the same antenna high on a mast but it won't be drastic. If your VSWR is really high near the ground something else is wrong.
Cdtompkins
I mounted it on a 12ft pole today and swr still bad, i have new coax installed also
KMG54
Did you adjust the top mast for the 11mhz band? that part is adjustable and needs to be. I have the same antenna and can hit half the world easily.
KMG54
I run mine on a Stryker 955 with LMR 400 and the highest swr I get is 1.3:1.
KMG54
Give us your setup so we can help, radio, coax amps?
