Site down??
brcoz
Florence, AZ
Same here. Slow then no server then it is back real slow. Asking for user and pw. I'll try later
WNC
The site got overloaded and feeds went down during the Vegas shooting. The servers can only support a finite number of listeners
ibagli
Ohio
My feed is still having intermittent trouble connecting. I thought it might be at my end but I've noticed that the number of feeds online is dropping substantially each time it happens (by about 2,000 this time).
Edit: Now it and a bunch of other feeds have been out for about fifteen minutes. All the previous outages were less than five minutes.
cobraultra
Pittsburgh, PA
I seem to be having up and down issues with one of my feeds. It is attached to Audio1. All my other feeds are fine but on different servers.
CRVFC500
Chestnut Ridge, Maryland
The last time this happened I needed to change a DNS setting for my server to talk to broadcastify servers. Can somebody remind me what this setting should be just to make sure my setting is correct? I recall there was a change when a replacement server was placed in service about a year ago. I still cannot connect to my feed because it connects and then immediately stops playing.
Sent from my SM-T827V using Tapatalk
ecarvalho
No clue... what if we try the IP instead of the domain?
Assuming this could be a DNS problem
Tech792
Central NJ
Same here. I run 2 feeds. Audio 1 is constantly up and down while my 2nd feed on audio 3 is running fine.
ve1jot
Liverpool, Queens County, Nova Scotia
up/down and latency
Gosh, glad it's not just me...seeing up and down on my feeds quite a bit now..packets are getting lost somewhere between me and server:
"--- audio1.broadcastify.com ping statistics ---
55 packets transmitted, 41 received, 25% packet loss, time 54381ms"
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
I don't recall which server my feed is on, but I have had several up/down alerts from about 2345 last night (MST) onwards. Usually comes back in about 20 minutes (just long enough for me to get the 'down for 16 mins' message).
cobraultra
Pittsburgh, PA
i opened a support ticket with them.. dont know if they will help at all... its been up and down almost every 15 minutes.
flythunderbird
Grid square EM99fh
I am seeing the same thing. My feed on Audio1 has bounced multiple times since yesterday afternoon, while my feed on Audio9 is rock solid. They'll get it fixed.
scottct1
Newington, Connecticut
Yup my feed is on audio1 as well and keeps on bouncing up and down.
I thought there was something wrong with my encoder, as my other feed (on a different server) is running fine.
