Site Locations
Front Range of Colorado
Hi All,
Does any one have the lat/lon's of any of the following Colorado DTRS Sites?
Thanks in advance,
Mike
157 RatonPass
159 CordovaPass
160 12Mile
162 PuebloChemicalDepot
163 Hugo
172 Kiowa
227 WolfCreekPass
228 CoalBankPass
231 KingMtn-Toponas
239 Iles
262 SandovalMesa
267 COG
269 PonchaSprings
270 Silverton
279 Egnar
n0nhp
Grand Junction
157 RatonPass 37 00 03.4 104 28 58.7
159 CordovaPass 37 20 26 105 01 28
160 12Mile 38 00 58.9 104 59 50.6
162 PuebloChemicalDepot 38 16 21.8 104 20 39
163 Hugo 39 07 54.9 103 28 25.8
172 Kiowa 39 20 59 104 28 45.3
227 WolfCreekPass 37 29 34.8 106 48 04.4
228 CoalBankPass 37 41 52.5 107 46 44
231 KingMtn-Toponas 40 01 13.6 106 48 24.5
239 Iles 40 21 04.9 107 32 04.5
262 SandovalMesa 37 06 03.3 107 18 00.9
267 COG Still showing an unknown callsign
269 PonchaSprings 38 30 20 106 04 56.7
270 Silverton 37 48 22.9 107 40 26.2
279 Egnar 37 56 30 108 54 32.4
And if you have a garmin
http://www.radioreference.com/forums/attachment.php?attachmentid=14019&d=1204128072
However this file was built in January and a few sites are not in there yet
Bruce
greenthumb
Colorado DB Administrator
If someone has these in decimal degree format and can submit them to the database and/or post them here, I will work the coordinates into the database so that you can use the web import function to bring them into your scanners.
Also, is there a standard radius that everyone is using for each site? Some local help to that end would be great too.
n0nhp
Grand Junction
The radius will vary greatly.
Western Colorado and the Eastern plains will be 50 mile or more.
Very few of the cars that use Abajo will be within 50 miles of it.
The Front range metro will be as little as 5 miles up to 15 miles.
Just my suggestion is to default everything to 50 miles and let the users adjust the distances as they use the sites.
Bruce
greenthumb
I'm not seeing much discussion on this, so I will work the DTRS sites in with a radius of 50 miles. Radii can be modified by the owner of the scanner after the web import is complete.
greenthumb
I have worked the submission with the lat/lon of all DTRS sites in so they should all be there. Uniden 996 people, have fun! :)
Thank you to the kind contributor of the coordinate information!
greenthumb
Along the same line, are there any GIS gurus out there who can give the lat/lon (in decimal degrees) of the center of each county in the state and the corresponding radius (in miles) around that point which will encompass the entire county? This is needed for the correct importing of each county's talk groups from the RR database into a GPS-enabled scanner.
