sites
yegnal
When you have a system such as the one below, how do you program the various sites?
http://radioreference.com/modules.php?name=RR&sid=408
This system has three sites, I entered the primary sites frequencies into a system set but the control frequency is on site threes' list. I can't add site 2 and three frquencies into the same system because of duplicate LCN's
Should I enter each site and the respective frequencies as a separate system?
DickH
You should ask this question in the New York forum. Each site should have a Control Channel, even though it is not listed. These files may not be accurate.
But it would be logical to assume you won't hear anything from the World Trade Center site. And unless you're driving through the Holland Tunnel, there is no point in hearing that site.
That leaves only site 001.
W4KRR
Coconut Creek
Each EDACS site must be treated as a seperate system. You don't say what model of scanner you have, but in general, each site for EDACS (and Motorola as well) must be entered seperately, in its own bank or system.
DickH
Not exactly. EDACS, yes. Morotola, not necessarily, unless the systems are close geographically. In a normal scanner with banks, such as a PRO-95, you can theoretically have 25 Motorola systems in one bank (4 control channels per system). For example, Seattle, Portland, Salem, San Francisco, etc., etc.
yegnal
Thanks, I thought that would be the case. I have the Uniden 396T..
