Six meter AllStar node
k3td
Wake Forest, NC
I have installed an AllStar node #29867 on 52.550 MHz simplex in Georgetown, TX. If you are in central Texas, or already on AllStar anywhere, feel free to check it out.
The radio is a Kenwood TK-690H 100 watt mobile feeding a Kreco CO-36A shunt fed coaxial antenna. The Kenwood is connected via a Repeater-Builder USB RIM to a pc running XIPAR AllStar software under Linux OS.
Here is a coverage plot courtesy of Radio Mobile Online:
https://maps.google.com/maps?q=http://www.ve2dbe.com/rmonline/user/k3td/covs/RME5FEB45AA720_2.zip&mid=1388544855
If you haven't heard of the AllStar Link Network, here is a great overview:
https://allstarlink.org/about.html
I currently have my node connected to node #2135, which is the Wide Area Network Repeater System, in order to give it a great stress test. Here is information on node #2135:
The Wide Area Network Repeater System - W3WAN
Long term I plan to connect it to other six meter simplex and repeater AllStar nodes.
I want to thank N3XCC, KE6IYC, WJ8G and W9SH for their help in getting my AllStar node on the air!
Six meters is a great band for ssb, cw, the digital modes AND FM! There is a good supply of clean used Kenwood, Midland and Motorola FM commercial radios available on eBay and from used equipment suppliers.
I hope you will give six FM and AllStar a try - 73!
k3td
Wake Forest, NC
I now have my node connected to other AllStar nodes around the US on 6 meters. Enjoy!
aaron315
You might want to review 97.201(b). I would hate to see someone stumble into trouble they didn't see coming.
Allstar, IRLP, Echolink and similar systems are considered an auxiliary station.
Not trying to start a huge argument or scold anyone. Just a heads up on what is likely an unintentional oversight.
Sent from my iPad using Tapatalk HD
KD7YUF
Brownsburg, IN
While I am all for increasing activity on and awareness of the 6 meter band potentially getting into trouble is not the best way. Unfortunately in the Indianapolis area repeaters can't be found so as a result I have not played with that band since I moved out here nearly three years ago.
