There are times when I got very frustrated with the WS1098. I thought its was a scanner issue or an antenna issue, but it was actually the skip button acting like lockout instead of skip.
I will usually have a lot of channels programmed, when the busier channels get busy Ill press "skip" thinking that I can clear the skips later from the menu in the scanner or just turn the scanner off and on.
But it seems like scanner software wants program the skip button with "lockout" all the time. Ill select for the skip button to be skip, but next time I copy to the card, skip its set to lockout again.
Is this a bug? Any way to stop the software from doing this over time, its just another thing I have to check every time I copy the frequencies to the sd card.
