Skipping a frequency in a bank
gthanagan
Toronto, ON
I've got a 2nd hand Pro-106 and like it. However, the one frequency range I monitor has a particular frequency that stops my scan and forces it to be manually resumed. Without owning the software and cable, is there a way to blank or skip this one particular frequency? The unit was pre-programmed for me.
GumbyCT
NH Cty, CT
I think I would lock it out before I deleted it, to make sure that one is the problem.
Press Func > L/Out to keep it from scanning again after you power it off then on again.
Pressing just L/Out will lock it out 'Until' you cycle the power again.
gthanagan
Toronto, ON
Thanks Gumby, worked like a charm. Anyone have a good place to get the usb cable from and what programming software should I use.
jamesa53
IN
