skywarn frequencies with arc500
.I am using the arc 500 software. When I go to the scan list it shows me all the banks that are in my scanner. At the very bottom it shows a skywarn list as bank 22 that you can click onto. When I click onto this it opens a new window but the window is grayed out. If I upload the frequencies from RR data base it will go into the normal scan list to where you can pick what bank to send the frequencies to, but there is no bank 22 for me to send the frequencies to. I do not see any skywarn frequencies preprogrammed into my scanner. How do I add these frequencies? I have a pro197 scanner
jaybw
I'm having the exact same problem. Where is the Skywarn option ?
RDGDigital
MD - Eastern Shore
Make sure you're using "Expert View" (first option on the View menu). Then the "Conventional" Bullet under the "Object Browser" has a column called "Skywarn". This is where you can toggle Skywarn on/off for individual frequencies.
