I have a Uniden scanner 396xt and I have my skywarn freq programmed why don't Skywarn go Digital on my state system Ohio Marcs for crisper clear audio Please
Sounds like you're trying to listen to something from outside it's coverage area. Skywarn operations are generally on a VHF or UHF channel using FM. The typical amateur repeater is clear, essentially static free, with good audio quality. None of that is true if you try to listen from beyond that repeater's coverage area. The same is true for simplex operations, only more so.Its so static and noisy even with the best Squelch settings in Findlay Ohio get a system that doesn't have to be used everyday Im just saying its hard to understand the spotters report
Questions:I have the freq that is used from the radio club in the city
Something tells me there's more to the story. You should be able to pick that up on your fillings.147.1500 yes it is a repeater 3 miles give or take a little...
Actually, I can tell you exactly that and, by golly, I think I will:I ordered a new antenna to also help but its beside the point that were in the tech ages and you cant tell me the FCC and state government cant fork money over for Digital Equip
