SL7550 Firmware
n8dhw
Middletown, Ohio
Just received a used SL7550 currently running R2.02.01 firmware. But when I try and update to the last release the CPS gets more than halfway then throws an error #8862 Application has encountered a problem. Failed to access a file in the device.
Have never run into that before I have several other TRBO radios and have never run into that error until this one.
Any ideas?
P.S Running CPS 14.0 on a Windows 7Pro laptop.
Firebuff880
Boynton Beach, FL
More than likely you are trying to jump to far forward.
Start with something like 2.4 firmware before you try an jump to 2.6 or 2.7.
Any ideas?
n8dhw
Middletown, Ohio
Well I found that the Tanapa Number in the code plug doesn't match the Tanapa Number on the rear label under the battery. That could be why it's not updating
n8dhw
Middletown, Ohio
That's what I was thinking but don't have access to any earlier firmware packages than 2.7.
n8dhw
Middletown, Ohio
Attached are links to pics one showing rear label and the other showing the codeplug in CPS.
