SL7550 self pass test tone
LoveMoto
Just noticed my sl7550 stopped doing the self pass test tone on start up. I am always tweaking the code plug but there are no errors or warnings shown in CPS2. Any tips?
K2NEC
5F6
You should be able to enable it from the menu
LoveMoto
Yes it is enabled but it does not make the little beep anymore on start up, so is it not passing the self pass test? Radio works fine.
LoveMoto
The radio should make the little self test beeps on boot right? Or is it just after programming?
K2NEC
5F6
As long as the power up tones are enabled it should. Also make sure that you don't have all alert tones disabled. This would include the power up tone and would cause it to be muted.
