lwvmobile
DSD-FME
If anybody wants to add this to their info, go ahead, its for Lafayette County Site 243. IThe frequencies are probably a tad bit off though since I'm using cheap RTL-SDR dongles, so you might have to modify the frequencies to the correct stepping for this system, but its just where its center for me. I should also preface this and say I am a novice, so I can't verify with 100% anything here, but it works for me.
SLERS Site 243
LCN1: 851.377 <- Control Channel
LCN2: 851.8
LCN3: 855.99
LCN4: 858.48975
Again, I'm using cheap RTL-SDR dongles so those frequencies are probably slightly off from the actual frequencies, I'm not even sure what the correct stepping would be but those are the control and three LCN channels as best as I can tell from where I live just mostly based on signal strength more than anything.
I also don't really ever listen to it or mess around with Unitrunker very much though. Most all the traffic is encrypted obvoisly, but very very occasionally, I'll get some Fire Rescue in the clear.
SLERS Site 243
LCN2: 851.8
LCN3: 855.99
LCN4: 858.48975
