SLERS system
treman98
Riverview Fl. near Tampa
Has anyone found a way to monitor it. Why are frequencys listed if no scanner will work on the EDS encryption, Does anyone know if the scanner mfgs. are working on a scanner model compatable with code entry to enable talk groups within SLERS.
N4DES
Retired 0598 Czar ÆS Ø
South FL
There won't be any. The control channel is encrypted and would be a Federal violation to decrypt it.
As to why the freqs are listed, there is an FCC license attached to it.
treman98
Florida SLERS
Laws are made to be broken. I miss listening to FHP and FFWCC, It is a shame that someone does'nt have the DES encryption fix.
Just for info CCW permits will be valid on state WMA as of 7/1/06. THANKS FFWCC!
grem467
Houston, TX
even if a scanner manufacturer put in DES capability, how in the heck to plan on getting the key??
lets not even get started on ESK...
you would see a ProVoice scanner LONG before even one that handled DVP or DES, much less anything else. in other words.. NEVER.
If you wanted to listen bad enough, you could go get a ProVoice radio, with des and edacs, a copy of ProGrammer and sit and guess the keys.. not to mention talkgroups. again, unless you are EXTREMELY lucky.. not gonna happen.
