SLR5700 as Subscriber
DisasterGuy
Maryland Shore
I have a need to interface to a Tier II DMR system via offsite analog. Currently doing it with a CM200d donor radio but would like to move to something continuous duty and 1RU rack mount. Does anyone know if the SLR5700 can be programmed as a subscriber on a DMR system to use as a donor radio?
Tech21
No, because you wouldn't know what's going on. An slr-5700 is a repeater with no physical controls on the front panel.
It would be programmed with the subscriber frequencies and you would still have to have a portable radio to know what is going on and that radio would have to be programmed with the repeater frequencies, which would in turn make your portable act as a repeater and now there would be a random rogue repeater on the system causing headaches for the system owner.
You would have to make the portable receive only and still have to have another subscriber programmed normally to talk.
What you need is a mobile radio like an xpr-5550e, for example.
DisasterGuy
Maryland Shore
To clarify, I dont need to control anything. Interface would be from the accessory connector on the back for TX audio, RX audio, PTT, and COR and interfaced into an analog gateway on a P25 trunked system. My wonder is if the SLR can be programmed for talkgrouos as I don’t see a way to do that in CPS.
I have stacks of DMR CM200d and XLR 5550 radios but I’m looking for a solution that is ideally 1RU rack mount and 100% duty cycle
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
He doesn't want to use the SLR5700 as a repeater, he wants to use it as a subscriber, and interface to it. No need for controls. It only needs to be on a single TG/channel(from what I can gather, could be wrong), and the TX/RXaudio PTT, and COR would be connected to something else. No need for volume, channel changing or anything else. It's going to live in a rack in a shack or closet somewhere.
