BucksGuyUSA
- Joined
- Oct 14, 2022
- Messages
- 18
I have a cheapo little magnet mount antenna - the small whip with the center coil that I wanted to switch from BNC to SMA on the skinny little coax cable that it came with. No big deal, right?
SNIP!
Now I have this coax which has a slightly-too-small-diameter for the SMA connectors I have, unbraided shielding wire, and a stranded center conductor that is a complete PITA to work with.
I can tin the stranded center, but when I try to solder that to the SMA center pin, no matter how quickly I try to heat it up, the center coax insulation melts and swells up and it won't fit the connector properly unless I trim it down with a razor. The sheilding just bunches up, I can't get the connector to slide in...
Beating my head against the workbench here.
Tips? Pointers? Just throw out the cheap-o antenna? Replace the coax with real coax?
SNIP!
