fourthhorseman
One of the reason's that I believe Uniden stated was the possibility of interference at some freqs, birdies, something , also price, even if it only cost YOU 5 bucks, that might translate to 20 bucks or more price increase.
I think they have an internal GPS in that new CD/scanner thing. I'd also guess we will see it in the next generation of scanners now.
I wonder how that would work with a low in car mount though? I have my GPS antenna on the dash. Wonder if that chip/antenna has good enough reception? I do know earlier ones would loose it in weak signal areas and that newer chips do much better. (Been geocaching/mapping/etc/ since SA was turned off).
Ive seen No Interference...
I monitor across all services/bands.
LadyBird keeps the signal like a champ.
First cold fix was on my workbench, in my
house..with stock ceramic antenna. about 3
minutes..
and yeah, 5 bucks parts,,All of us would have been happy to
pay 20 for the feature to be there,,seems they could have put
a lotta smiles on faces..VS so much time spent on WIFI..That was a Cluster Funk!
Id rather have the GPS than WiFi..Which is more use able across the map..
But Oh..then they may have suffered a loss due to not as many sales
of that 80$ Uniden puck..that has like 9 diff cables..
This set up works for the 996XT, and the 536..(done 3 996XT's and 1 536)
and 3 436hp's
I use the UBLOX Neo6 for the base units..and the ladybirds for the handhelds.
Base units are fitted with a SMA for an external GPS antenna..either U.FL to SMA
or SMA to SMA depends on the UBLOX model..
SARENTEL antennas are great, and Very Low profile..(for base units)
https://www.amazon.com/gp/offer-lis...ms?ie=UTF8&selectedSims=B00CRCGUBW,B00K9ZZY7K
Currently getting ready to open up a 396XT and go to work..there IS enough
room in there! getting a BCT15X in this week..Should be easy too..
Have no fear, Trust your ability , and Void yer Warranty!..
But GPS with no wires..
TOTALLY worth it!
