Smartzone roaming issues
hyundaibus
I have a Motorola XTS5000 model III on a 400MHz trunked smartzone system with valid ID. All control channels are programmed in and all parameters are correctly set. The problem is the stupid radio will not switch sites nor will it change sites when the site search button is pressed. The site lock function is off (site unlocked). What is wrong with this crazy radio?
The radio has HOST/DSP version 10.
Liverdog
There are many things that could be at issue, probably more than can be addressed in this forum. Have you asked your radio shop/programmer and system manager?
One of the obvious is, are you in range of the other sites?
In the zone, your radio or talkgroup could be denied at the other sites. There are several possibilities.
hyundaibus
Removing antenna
When the radio goes to another site, I have to remove the antenna and put it back on and then it will go to that new site, no problem.
richardc63
Sydney Australia
Hi,
This is sounding familiar- we use this feature as a form of "quasi-Smartnet" operation in case of Zone Controller or multiple link failures. Go to the trunking personality & look for the Site Preference settings... check that this site has not been set as its "Preferred" or "Always" site. Make sure you check all trunking personalities.
This may have been done deliberately to keep this radio from wandering to other sites...
Let me know what you find!
Cheers,
Richard
hyundaibus
Smartzone Problem
All the personalities (sites) are set to NONE. I don't think the radio sees the sites that is supposed to, even when they are in range.
richardc63
Sydney Australia
That knocks out one possibility in the profile as the cause...
Next idea- has the talkgroups and/or radio ID been limited in the sites which they are permitted on? Talk to the System Manager to find that out.
Cheers,
Richard
GEMOTO
Atlanta, Georgia
I have noticed that when the radio is in scan it will not always switch sites properly. You also need to make sure that your SmartZone RSSI threshold values are set up properly. This information varies per radio model, although it does not have a large effect on operation it could still be contributing to your problem. Also make sure there is no local noise/interference on the control channels you are trying to hear. While forcing a site search it may not see the other control channels if they are a bit weaker than the local noise from computers copiers routers etc. I have seeen this problem before.
If you want, send me your codeplug and I'll take a look to see if there any obvious errors.
RKG
Boston, MA
A dollar to a doughnut says that the "SmartZone Parameters" are not set to match the parameters engineered for your system. (See "Trunking|Trunking Configuration|SmartZone", "|RSSI Thresholds", and "|Filter Constants.") This will cause the radio either to switch prematurely, switch late, or not switch at all.
richardc63
Sydney Australia
I think the radio has bugs in it. I have another radio that works properly.
RKG is probably right... I'm willing to bet that the trunking system part of the profile has errors in it. Why don't you take it to someone with (a) CPS and (b) more knowledge of the system/talkgroup configs?
Nothing you have described convinces me that the radio is actually "faulty".
Cheers,
Richard
