Smartzone-smartnet
Justin96
Ok well i am getting a XTS3000 with smartnet...does anyone know if i will be able to get Smartzone on it?
WayneH
Forums Veteran
Super Moderator
Sitting in an airport somewhere
SmartZone is a purchasable option. If you have SmartNet your radio won't support the features SZ provides, but it will work the other way around.
Whatever it is you want to add requires a system key to permit the system to be programmed in. Generally the system's radio dept has to program this in if you are authorized.
Hopefully you didn't just buy this radio used in the blind. Motorola trunked systems aren't programmed in like scanners.
GEMOTO
Atlanta, Georgia
A SmartNet radio will work on a SmartZone system but not to it's fullest extent. You can program the SmartNet radio to operate on 1 zone of the SmartZone system. You can actually program it to work on as many Zones on the SmartZone system as the radio allows you to enter trunking systems in RSS/CPS. You will not be able to Scan Talk groups from different systems or automatically rom from one zone to another.
Say the SmartZone system had 12 zones. In CPS it allows you to enter 8 trunking systems, in which there are trunking personalities. Each system could be a different zone on the SmartZone system.
