re Post 45 - I will guess that -
You have the general idea.
A/G Cmd is for coordination between overhead administration (Division Supervisors, Branch Directors and Ops Chiefs) and aircraft
A/G Tac is for coordination between aircraft and the firefighting resources on the ground. If there are active drops on a Division, every firefighter on that division will be monitoring A/G to make sure they don't get dropped on, or tell the aircraft if the drop was off target. Sometimes both command and tac fit on one frequency. For large incidents, they separate the two.
Air Tactics is fixed wing operations
Air Briefing is used typically for briefing incoming relief air attack or other overhead coordination. It's usually an AM freq (smaller incidents just use 122.925 or a quick adhoc vic freq they decide over the air, larger incidents have a dedicated brief), but 2020 I've seen a few FM freqs for this and I think that's to be an alternate coordation freq for non-firefighting support aircraft, ATGS and Lead, and could even have IR ships, drones, etc.
NIFC Command repeaters are for all command and operational coordination on an incident. They are portable VHF repeaters that are all linked together by UHF links. Every repeater is a unique pair, there is no common input freq. With the link, you pick one repeater, they all come up.
Helicopters are required to have 2 FM P25 capable radios on board, one of which must have a dedicated Guard that can be activated at the flick of a single switch, and 2 AM radios on board. Normal incidents they'll just have Air Ground, and Rotor Vic. Bigger incidents they'll have A/G, A/G Cmd on the FM's, Rotor Vic, and TOLC (take off landing coordination) on the AM's. When off the fire A/G gets switched to Deck.
