Question, did that vertical arm that the ST2 is mounted on, that is in turn mounted to the conduit, come with your ST2?
The HORIZONTAL arm is part of the antenna. There is no vertical arm in the photo.
What works better to mount the ST2 on. A PCV PIPE or a metal pipe.
Yes, the vertical bracket comes with the ST2 antenna. Most the them come with a 50' coil of RG6 cable, too. And, as for using it for tv signals, I found mine didn't work very well for that. But then, I had it vertical-mounted as its made to do, and I'm between 25-30miles from the tv transmitters in Birmingham.
Thanks. I'm wondering about reinforcement of this antenna with the fiberglass bike flags, if anyone has done this or similar - did you do it during the install or after? Trying to decide if I need to build it then run reinforcement or do it while I put it together...
Lowes has fiberglass driveway markers that are about 1/4" diameter and 5' long, would be a good alternative to the bike flag poles.
If 700 mHz is all you listen to and you don't need the broad frequency coverage of the ST-2, then a dedicated antenna for the 700 mHz range is likely to do a better job. Optimum, pricey solution will be a 700 mHz omni gain antenna or Yagi beam. But before going that route you may want to try a simpler, cost effective approach: Use a TV antenna turned so it is vertically polarized. Remember, the recently relocated TV channels were moved off of 700 mHz to make way for the P25 and other public service stuff you are trying to receive. So those TV antennas are tuned for 700 mHz. You just need to change them from horizontal to vertical polarization, usually by rotating them 90 degrees on the axis when mounting. And even the "HD blade" style wall/window mount TV antennas can do wonders for the much lower price of a TV antenna than a (comparatively) expensive 700 mHz commercial comms antenna.
Just cut the reflectors off & I'm good to go.
Along these lines, I was wondering... If I want to get maximum signal from 800 towers to my north & south... I would orient my yagi east & west - so that the broadside of the antenna faces north & south, correct?
Incorrect polarization can make a 3dB or more difference in the received signal.... for weaker signals that could be enough to bury them in the noise. For most all VHF/UHF 2-way communication you want to ensure your Yagi is vertically polarized.... that is, the elements will be vertical (perpendicular) to the ground.... not parallel to the ground like a TV antenna. Once you turn the Yagi to vertical, come back and let us all know here how much of a difference it made.
