So what exactly happened to the trunking firmware?
radio3353
Sadly, I was once an enthusiastic fan of Unication. While I still very much like and use my G5, I have soured on the company for their lack of response in the past year or so to problems and suggestions. I know, let's just blame it on Covid :rolleyes:
llzel
They responded quickly in modifying the firmware to fix a glitch I and others were having.
wa8pyr
Technischer Guru
Staff member
Lead Database Admin
Ohio
I know I read of several users that downgraded successfully, disregarding the Unication warning not to. But I have not heard of anyone that has tried it with negative results. Has anyone here "downgraded" to the latest 1.31 with negative or catastrophic results?
Just my uneducated opinion, but it feels to me Unication used us as guinea pigs to test out the scan feature so they can implement it into their "new scanner" that is on their website. There hasn't been a firmware upgrade since December 2020, and they promised me a fix for my $150 Amplified charger back in November 2020. Haven't heard a peep.
I downgraded my G5 to the latest non-beta (pretty sure 1.31) just fine. Didn't have any problems, but YMMV.
wa8pyr
Technischer Guru
Staff member
Lead Database Admin
Ohio
Modern radios cannot *PROPERLY* scan between systems or conventional. It is a hardware issue, and one that would require a completely separate tuner.
While scanning the alternate system or conventional system critical traffic is going to be missed on the primary / priority system which is a deal-breaker for the industry which these devices are intended for.
I concur with GTR8000; the feature should at least be there.
You are correct in that traffic can be missed when scanning between trunked and conventional, but that choice should be left up to the owner. I have quite a few county public safety users here who want to be able to scan between trunked and conventional, and while I caution against it, it's their radio and if they want it they'll get it, whether I do the programming or some other shop does it.
mdsxfire
EDBM
Uxbridge, north of the river Thames
Just my 2c, I was testing the 1.4 f/w and used it for a few weeks. The time it took to scan between trunked systems and acquire the CC was way to long. If I caught any transmissions it was always the very end then it would switch systems and I would miss the rest anyway.
I downgraded to 1.3 and have since upgraded to 1.32 and have notice no issues.
unication worked very quickly with myself and a few others who were having issues with specific systems, within days of sending them my log files they sent me an updatedF/W that fixed the issue. While I think unication could make the best scanner in the market they make pagers right now, and from 3 years of usage as my primary pager it works perfect.
burner50
The Third Variable
NC Iowa
Given that we are in the middle of a transition from Analog conventional to P25T P2, I would *LOVE* that functionality. We are P25T as well as law enforcement, but fire is not and a couple neighboring counties are not on the new system either.
But with the hardware limitations, it isn't feasible as things start to get missed pretty quickly.
burner50
The Third Variable
NC Iowa
"I can't admit I was wrong, so I'm going to come up with some other BS"
Well, since I'm not wrong...
It doesn't work for people who need the radios. It's okay for scanning or monitoring, but doesn't work for the people you're monitoring... Since the G5 is designed and mainly marketed as a pager as opposed to a scanner, the functionality should mimic what the served agencies require.
62Truck
Ordinary Subscriber
Uranus
But you were proven wrong..
Bro, its okay to be wrong every once and awhile. No one person can know everything. Try it out, I think you'll sleep much better at night.
trido
Southern In
NO we have no NDA.
I can say very recent info from them they are working on the scanner NOW and I was told hardware is ready for scanner and they are working on the software.
When I have more I will post.
To be CLEAR this is a NEW Unication Product a scanner.
im assuming that the testers are under some sort of Non Disclosure, but yeah it kinda fell off the map, disappointing
12dbsinad
Our state police agency ended up installing Kenwood mobile radio's to scan conventional channels. The issue is priority. Even though it can be done, it isn't practical. There is a big difference between scanner hobbyist and actual public service in regards to scanning and the expectations.
seth21w
Somewhere monitoring the air.
NO we have no NDA.
Yeah but why would we buy another 600 dollar radio that is the same exact radio just for scan feature when we already know the one we have now is capable?
trido
Southern In
we just have to wait on it. current g 4 and g5 are pagers not scanners.
the new g scanner i expert to perform more like the sds models.
we will know soon i am told.
bob550
Albany County, NY
Well, no one says you have to buy one. But if you're now primarily using your Gx as a scanner, there may be performance improvements via hardware changes that will make a Unication scanner attractive to many current owners. That, and don't forget the huge segment of the scanner user population that don't now own a G-series.
seth21w
I have an sds100 and a g4 I'm not interested in buying another scanner. I simply would like to have 2 systems programmed into my g4 im sure the hardware internally will be similar to the g4.
trido
Southern In
I cant promise I will even get an answer however I did just ask if they would consider opening up the beta firmware to all so they can scan multi systems.
Does the beta work yes it will scan multi knob pos that are trunked systems.
Does it work as well as the sds scanners NO.
I post if I get an answer.
QUOTE="seth21w, post: 3536622, member: 287356"]
[/QUOTE]
radio3353
NO we have no NDA.
trido,
Do you know if the expectant scanner design is base or portable (or maybe one of each)? Thanks.
burner50
The Third Variable
NC Iowa
Because multi-system scan doesn't work reliably or have the ability to properly work as a radio when scanning.
That's the point I'm trying to get across, but others seem to just fold their arms and say "NUH-UH"
I think others have forgotten that Unication pagers are *Pagers* intended for public service use... They're not a scanner, but have some similar functionality. Sure, Unication is hoping to expand on that somewhat, but at the end of the day, the hardware was intended to be a pager, not a scanner.
12dbsinad
Unication is going to develop and spend time to R&D things that are going to benefit them profit wise. It's doubtful the scanner hobbyist are lucrative.
