software arc-500
baboon53315
Oshawa,Ontario Canada
still problems with my psr-600.i have two systems in my radio-durham fire and whitby tower for opp and ems.when matched against my 996 the psr600 seems sluggish or slow.is there something under global settings:expert that needs to be changed or am i just doing something totally ******* wrong????
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
A 'sluggish' scanner may be how you have the scanner setup. Give more details or better, yet zip and attach your ARC file so we can determine your settings. .
baboon53315
hi.not sure on sending zip files.this is whats in the radio--trunk systems-2,supertrac-on,multisite-off,threshold high-95,threshold low-75,dwell-0,digital agc-on,object id-0,10,chech id-no,talkgroups-77,delay-off,scanlists-1,2,3,are used,misc.tuneled&talkgroup ignore-on,show cc info-off
func.global expert settings
maxtune-20
sq wait 1-10
sq wait 2-15
rfsq fade-10
dg int prime-60
all wx are-0
sweepscansq2-5
sweepersrchsq2-5
sweepeersrchsq1-10
sweep am delay-150
sweep pm delay-50
spcl sweep limit-5
srch times-0
flexstep-off
trunk ch#-off
ccdump-off
dsp dump-off
2m delay-5
ac sq poll nt-100
ac sq srcint-500
hd5 fade-2000
hd2 quality-75
hd2 holdoff-500
96cc hd2-30
96vcsq to-50
96vc xf to-100
hd2 qual dg-100
subaudio delay-150
m36et patt-2b2b
endtone mot-80
endtone edacs-10
edacs unmute-18
edacset ho-35
rssi signal
bar 1-370
bar 2-450
bar 3-520
bar 4-610
bar 5-680
zero matic
5k inlo-252
5k inhi-552
5k outlo-210
5k outhi-594
outlo-174
outhi-633
last one is batt.cal
