Software for the IC-F3GS-2
wcu02mpa
Asheville,NC
I have a VHF IC-F3GS-2 and cannot figure out which software to use. I have tried several....IC-F3G and F-33g and it won't read. I also assume it uses the same programming cable as the IC-F3.
Mike
Alloy
Cables can be had on ebay. THere are 2 different versions. 1 that uses a serial port and once that uses USB. Although I don't believe the USB I have is from ICOM.
