Tytera Software for Unlock Hidden bands and edit System parameters on TYT TH-UV98, TH-UV99, Retevis RA-89
inside4rom
We are present new Limited-Free Software for Unlock Hidden bands and edit System parameters on TYT TH-UV98, TH-UV99, Retevis RA-89
Features:
Faster and Quickly methode of Reading/Writing bands by collapse UHF to 446 - 448 Mhz or Expand to 400 - 520 Mhz.
Unlock hidden Satcom bands 200 - 260 Mhz.
Edit battery voltage sensor constant : Actual for TYT UV-98, where radio make "beep" as signalise Low voltage under 7 volts. where other radiostations work wel for discharge battery on 6 or less volts.
Read/Write Eprom settings for save dump for future repair or share ur settings for friends for easy cloned ur settings on his radiostations.
Also:
Software is used "Autodetect Comport." by driver name, available for use with CH340,CP210x USB to UART, and Prolific PL2303 Usb2Uart cables.
And simple option for REad/Write Full Memory backup from ur radios (for easy repair in future or backup before play with radio programming etc..).
Adenium:
Basic reason of creating this software stay be whatsoever the complete disregard on the part of the developer-manufacturer and the store where I bought it.
I use two emails for write about problem with TYT UV98 to Chinese company and leave him online message on his website. They are fully ignored my request .
Also shop where i buy is nothing reply from how to solved Low Battery voltage detection under 7 volts battery voltage, when other radiostations like Yaesy VX6R can easy discharge battery to 5.4 volts. So when i study this radios i found one temporarily way for edit battery sensor voltage to "+1v", and now my walky-talky run "beep" under 6 volts. So, via all this reason i write by funny name as Tyt - Bul**** Repair tool :)
Software now free, for use you need write me Hardware ID, and i add activation to server for you can easy and freely use our software for next 7-14 days.
Important!
Since my requests were ignored by Chinese developers and sellers, I forbid them to use this software!
Download link here: Index of ./Files/
Best Regards.
IZ6OUF
Come posso procedere per sbloccare le frequenze della mia radio? Posseggo un Polmar db-10 mk2. Grazie mille.
WSBRUT
Got the software up and running. Will be reaching out with my hardware ID.
Thanks for putting this together!
WSBRUT
Here's what the program shows:
Connecting TH-UV99 - Ok
FE FE EF EE E1 55 56 39 39 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 34 33 34 45 00 00 FD
Read memory ...
Internal Model Name: Retevis RA89
------------------- Band List --------------------
VHF RX: 13400000 : 17600000
VHF TX: 13400000 : 17600000
Sat RX: -1 : -1
Sat TX: -1 : -1
UHF RX: 40000000 : 48000000
UHF TX: 40000000 : 48000000
Battery callibration constant: BCh 188d
Successed, file: tyt_memory-backup.bin
Thank you!
inside4rom
Read memory ...
Sat RX: -1 : -1
Sat TX: -1 : -1
Thank you!
Hardware ID the computer ID , and software show when you try run first time and not make any operation.
I see ur radio is not supported Satcom bands from defoult 200-260 mHz bands, is right ?
WSBRUT
I see, here you go!
hid: 566C4F3966652F713074326B6444615533454145695A5A7858517671456F2F765178745269773D3D
Correct, not supported from default. I assume this software will fix that?
fatuq
Whats the id and what should ı do can you explain step by step?
