Software Help
emsflyer84
Central NH
Hey guys, I just picked up a TRX-1 and I’m having trouble figure out the software to program the unit.
I got all the frequencies I want downloaded from the database (all conventional) but I can’t figure out how to organize them into scan lists, name the scan lists and get the scan lists uploaded to the scanner.
Any help would be much appreciated. Thanks!
Why aren't you using the EZ Scan database to update/program the freqs? Have you updated the Library database in EZ Scan? I'd recommend that first.
On the far right of the EZ Scan Conventional tab just click on the SCANLIST column and select the scanlist you want
On the General Settings tab in EZ Scan select the scanlist you want to name click on the name and enter what you want
Go to SCANNER/SD CARD tab at the very top and click on copy configuration to scanner/sd card.
Also, backup your configuration by going to the FILE tab at the very top and selecting SAVE CONFIGURATION TO ARCHIVE
rayvelcoro
I just noticed you posted this thread so never mind my saying that you've mastered manual programming.
emsflyer84
Central NH
I did master the manual programming, but I think using the software could be easier as you can make changes and adjustments to batches of frequencies instead of one at a time. I’ll keep playing around but I think I got the hang of it today.
