Software Recomendations for SC230?
frank10
What about the lite v.sport versions?
The lite is cheaper and apparently has everything but the
Virtual Control
Data logging/history
Closecall/Subtone logging
whaterver those are.
DaveIN
Founders Curmudgen
West Michigan
The lite version is great if you just want to program the radio and head for the race, or change System memories for going out of town or on a trip.
If you want to use the 230 for other things, such as logging when you are away from home at work, or use Close call to find nearby srong signal frequencies, or Subtone (CTCSS/DCS) logging.
frank10
It sounds like the lite would work for me. I'm going to check with them to see if I can upgrade from the lite to the full version later on, if i decide to.
