Software Suggestion
JustN
Afternoon-
Looking for suggestions on software to use for Control Channel decoding... My main goal is to monitor a local 800mhz Motorola system to put together a list of Control & Voice channels. My main scanner is a BCD996xt with the sound and serial ports connected to my Desktop PC.
I tried mtrunker32, but it appears that a data slicer is needed -- I can get about 70% accuracy using this application at best (though other programs like Unitrunker and UniTrunker get 100% accuracy), it reports the local system as being a Type II Astro system. At 70% accuracy I get a system type and that's all.
I have tried Pro96Com and it works great for the local P25 State-Wide system, but does nothing for the local Motorola system.
I have tried UniTrunker for Windows and it seems to work OK, but doesn't tell me much -- I know some of the programs will report Active Control Channels (which I do see in UT), but doesn't report Alternates, etc...
Am I missing some software somewhere? Is there something more in-line with the BCD996xt hardware, maybe that uses a direct feed from the control channel output?
J-
Highpockets
Toms River, New Jersey
Afternoon-
J-
Try Trunk88, read about it here:
Trunked Radio Decoders - The RadioReference Wiki
And you can DL Win32Trunk88.Zip Here:
Index of /~phoenix/wap/TRUNK88
Also a little help on getting started here:
http://forums.radioreference.com/1163971-post4.html
JustN
Thanks Steve, that seems to be working very well it's up and displaying grants, etc...
I do see two error messages, however -- "System Type 65535 is invalid (should be 1,2,4,8 or 16)" and "Current site is not sending SysID command". I changed the System Type setting in the CTL file to "System Type = 2" as it explained, but that doesn't seem to work... And I'm not sure about the current site not sending a SysID command.
It also appears that even with the other programs, moving back to Windows XP has brought a major improvement. I tried running Trunk88 on my Windows 7 PC (which is where I ran all of the other applications) and wasn't able to decode any data -- on XP, I'm running with a Cur Acc of 100%.
JustN
Also -- it seems to me that Trunk88 is reporting only Digital communications on the system I am scanning... When a Digital TG is activated, Trunk88 shows the frequency, etc.. -- but when an Analog comes up, Trunk88 never hears about it....
slicerwizard
Toronto, Ontario
You need to set the value in the system's CTL file, not in TRUNK88.CTL
That's not an error message. It's just telling you that the site isn't sending a standard SysID broadcast. A few sites out there are like that.
Probably a sampling rate error. It'll be addressed in future releases. You could also try different sampling rates.
Sounds like an incorrect or missing System Type.
