Software to listen to pager tones??
dgoodson
Florida
I have used "NCH Tone Generator". which you can download for free to do this... sort of.
Set up your first tone, then "play" it from your speaker output back into your mic input and use Sound Recorder to record it as a .wav.
Then repeat for the second tone (and save it with a different file name, of course).
Once you have the two tones saved as files, Sound Recorder is very easy to combine and manipulate them into a single file that will sound like pager tones.
whitesox4life
Grant Co, IN
Is there any where to just play / create fire tones? I have some pagers that I am setting up for a fire dept but no body knows what the tone freq is for their pagers. I dont want to have to download anything (my computer is slow enough already).
