solar panel to power my radios
ASAD
Bucks County, PA
Hi. I would like to use a 25 watts solar panel, a charge controller and a 12v battery to power my shack. I will be using a Renogy 20 amp MPPT 12v solar charge controller to charge the battery and to power the radios at the same time. I was wondering if this Renogy charge controller gives out regulated DC output? Is it safe to connect the radios directly to Renogy charger? I also have Astron BB-30M module but i think it requires a regulated DC input. Another question would be, is it safe to directly connect the Astron BB module to the Renogy charge controller?
My aim is to have solar power during the day and automatically switch the load to the battery during night or cloudy conditions. This is because the scanner will be on 24 hours.
I would appreciate your advice.
trentbob
W3BUX- Bucks County, PA
Ambitious but hardly worth the trouble unless you have a real problem paying your electric bill, your scanner being on 24 hours a day is not going to break the bank. You didn't mention what kind of scanner or if it had a data card also don't know what other equipment you have in your Shack to make this worthwhile trying to save on your electric bill.
Doesn't seem like it's worth it for all the trouble and expense, how it'll actually work, I personally wouldn't be that curious to find out LOL.
What is your motivation for doing this, just wondering?
737mech
Clark County, NV.
How much power do the radios need? On battery only you are limited to how many amps is in the battery. The solar charger might keep the battery charged however you are also drawing from the battery during the day. How do you intend to isolate the battery so it can charge? The output from the mppt is it 20 amps? Doesn’t seem like it. The output from most 25 W panels is usually about 1.43 amps. So 1.43 Amps minus the radio load is what is available to charge the battery.
I looked at their webpage and the only 20 amp MPPT controller I could find looked like they intended for the load to be connected directly to the battery. The battery should regulate your voltage just fine.
My concern with this design is that there's no low voltage disconnect to protect the battery in this setup. Leaving a radio on and over discharging a gel cell will quickly destroy the battery. If you are using one of the fancy batteries, it may have a low voltage disconnect built in.
The systems I've worked with have the load connection as part of the solar controller, and that handles the battery protection side.
No, like I said, the design appears that they want the load connected to the battery. You shouldn't need the battery backup module as that's part of the role of the controller.
Yeah, I think your panel size is way too small. A solar panel rated at 25 watts is only going to give you the full 25 watts in full sun. You'll only get full sun for a short part of the day. That 25 watts from the panel will need to recharge the battery. At the same time, your scanner is going to be sucking some of that power. Probably a few watts at least, depending on the scanner. That means that the battery may never get fully charged and eventually the battery will not be able to keep up. Remember that you not only need to power the scanner, but have enough power available to fully recharge the battery. Battery needs to be sized to support the load all night long, plus support it when the solar panel is unable to generate enough to power the radio and recharge the battery. This design requires some careful calculations. I've been through this at work where someone tossed together a solar system at work to power a remote network access node. They panels were not big enough to power all the equipment during the day -and- fully recharge the battery. They couldn't understand why the system kept crashing every night. They kept adding more and more batteries, but they never had enough panel output to keep them charged.
Think of the battery as a gas tank, and the solar panel as the gas station.
Your gas tank might give you 400 miles range when full. But if the gas station never fills the tank up all the way, you won't be able to keep driving 400 miles. Eventually you burn up all the gas in the tank (battery) and if you don't fill it all the way (solar panel), it's just going to leave you stranded on the side of the road.
I've been doing the solar powered radio site thing at some of my remote work locations for about 10 years and it really takes some careful design. Before you purchase any hardware, you really need to reconsider your panel size and battery size.
prcguy
You can't run equipment directly from a charge controller without the battery, the controller charges the battery and the equipment connects to the battery or through the charge controller with the battery connected. Some charge controllers pass battery power through itself and can disconnect devices if the battery voltage gets too low which can damage the battery.
I would upsize the solar panel and also make sure your battery capacity will power your electronics for a couple of days without charge if needed.
dkcorlfla
Orlando
Some notes on my 200 watt system that might help. The MPPT controller has four modes it automatically cycles between depending on how much sun and the battery voltage and also the number of days. It will go up to 14.9 volts on the equalize cycle it does once a month. That might be a bit high for the radio. 200 watts is enough to charge the 100 amp hour deep cycle pair of SLA batteries (one at a time) I have on a thick overcast day. I have the two batteries setup with a pair of thick cables so I can hot swap them and leave one open and out of the circuit with a full charge. I swap them once a week to keep both charged with one in reserve if I need it to power stuff in the house. I have a 1000 watt power inverter that will run the TV for a bit (local news) lots of LED lights and my scanner + one of the computers. It should also power my ham radio equipment but I have not tried it yet.
Make for a really nice and simple to use system that beats the heck out of a generator for short term power outtages.
Can provide some pictures if it would help.
dkcorlfla
Orlando
The MPPT controller needs to be hooked up to a proper battery 100 percent of the time. The manual said do not connect the panels without a battery hooked up as it will damage the controller.
