soldering iron or kit
gator
Mitchell,SD
does anybody know of a good place to get a soldering iron or kit so I can put a tap in my 796d
still learning so any help is appreciated
Monty Haynes
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
Radio Shack, Lowes, Home Depot, Advanced Auto, Auto Zone, NAPA, and maybe a 100 other places near your location. You should need to solder at the most, 5 places.
gator
Mitchell,SD
thankyou
thankyou for the info
Do you know if Walmart but carry it
and do you have any idea what those 5 places are you are telling be about
and one more quick question will this ruin my audio if i tap the radio
Monty H
loumaag
Silent Key - Aug 2014
Katy, TX
Monty,
That is a lot of radio you are thinking of opening up and applying a soldering iron to. Do you really need to run Trunker? I am pretty sure I know what you are after and probably you could do just as well running ID Tracker software using the standard connection on the 796 without having to open it up to get at it. Just my $0.02.
If you really want to run trunker, do you have an older scanner that covers the frequency you are after, once you tie up the scanner using it with Trunker (although it doesn't really hurt the scanner) it does become useless for anything else while you are running Trunker with it. I mean either you run Trunker (or T4Win) with the scanner or you use it to listen to, you can't do both at the same time. :)
Hope this helps.
P.S. -- I think you know how to get hold of me off the board and I can give you some places you can find soldering stuff, etc.
gator
Mitchell,SD
Lou's good advice
thanks for the message Lou you must follow this forum and much as I do,
I think I am going to take your 2 cents and not open this up to risky and the only one I have I got all the state stuff programmed my problem right now is trying to figure out this federal prison TRS here in Yankton .
once again thanks to a scanning buddy i
Monty H
jomak
Lakewood, Colorado
Monty,
In the spirit of promoting the hobby, I have occasionally done this for several others and I will offer the same to you. I am kind of well known both here and on the Strong Signals site. I am fully qualified to do these mods for you. I am an electronic technician in the USAF with well over 20 years experience and have all of the equipment necessary to do SMT soldering and repair. As a matter of fact, I was stationed out at Ellsworth from 85 thru 94. If you supply all of the materials and pay for shipping both ways to and from from New Mexico, I'll do the mod for you.
JT Makatura
scannerfreak
Well Known Member
Indiana
Re: Lou's good advice
Monty H
If you really want it tapped and dont feel comfortable doing it yourself, dataslicers.com will do it for you for a fee....
Dubbin
Findlay Ohio
I just wanted to vouch for JT if you take him up on his offer.
fmon
Eclipse, Virginia
Me too, many of us have mods by JT Makatura.
