- Joined
- Feb 27, 2011
- Messages
- 1
When the christian louboutin outlet high-heeled shoes altitude to 6-8 cm in when you walk, your body gravity will naturally up. A study found that, if you wear the high-heeled shoes of 7 cm walked two hours, neck stiffness will be increased by 22%, health experts usually don't recommend long face computer OL wear the high-heeled shoes outlet of 6-8 cm, and that will only make your neck was more and more tired!
Solution: recommend you wear jimmy choo outlet high heels, 2 hours per the shoes off, let double foot rest 15 minutes, and do some moderate foot massage, key press can alleviate muscle tensity, located in foot before 1/3 point of yongquan acupuncture point. In addition, if your heel height at 6-8 cm in between, don't wear overweight necklace, lest neck compression excessive.
