Some Channels Not Coming In
horrocks
South Carolina
I have a new BCD396XT and live in Monroe County NY. I downloaded this county into the unit and I get Webster, Irondequoit, and Brighten Police, the county fire, and some others, but I do not receive the Rochester police or the Monroe County sheriff. Any ideas what I may be doing wrong? I am new at this. Thanks in advance.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Did you allocate and enable quick keys for each of the ones you aren't hearing, or are they already a part of an active group? Are you using an outdoor antenna - perhaps they are too far from you to hear. A duckie - that little stick antenna that comes with most scanners - is a compromise at best, and that's putting it politely. Did you cross check your programming against a different known site, such as NF2G.com?
Sometimes the easiest way to debug the issue is to dump the contents into a file that people can then examine. What software are you using? 73 Mike
horrocks
South Carolina
Mike,
Thanks for the quick response. I am using s/w ARC-XT demo version. If you give me your email I can send you the profile. Reception should be there, as they are close. Also, Rochester police is part of the larger group. I think I just read that radio reference has not yet updated their conversion to digital. They changed over on January 10th.
Thanks,
Mike
horrocks
South Carolina
Mike,
I am all set now. I discovered that the digital frequencies were set to analog. All work fine now.
Mike
