Some DOS-based RSS crashes immediately
knockoffham
Michigan, USA
Hello. It is me again back with something annoying. Today, I am trying to program some MT2000s. However, whenever I go to run the MTSX software, it shows me something about 'Phar Lap's 286 DOS Extender" and then crashes to the DOS prompt with no given errors. I have tried a few versions. This also happens on the old DOS based Astro RSS and a few others that also use the format with the ".ODB" files and "RUNTIME.EXE". My computer is a Pentium II and I have tried from a FreeDOS boot disk and MS-DOS boot disk. Interestingly it seems to take slightly longer to crash for MS-DOS than FreeDOS. I have tried with EMM386 and HIMEM both on and off. I suspect the problem is with memory management when this DOS extender runs, because I have googled it and it seems problematic in its day. It is probably not a CPU speed issue- I have successfully programmed many Motorolas with this computer and older RSS packages, and this version of MTSX is dated some time in this century I think. Any suggestions? Thanks.
RFI-EMI-GUY
May not be related, however I found some old RSS would crash because, when copied, or zipped, by others,,, the archive bit, or read only would be set for files that actually needed writing to during execution.
knockoffham
Michigan, USA
Thank you for the help everyone. I figured it out by running it in DOSbox with some debugging. I was running the software from a CD, and the RSS was trying to create a temporary file as soon as it started in the current directory, and obviously couldn’t due to it being a read only CD. So it would just crash with no error code. Manually typing “d:\MTSX\runtime -o d:\MTSX\MTSX.ODB” instead of CDing to the directory it was installed to and running the batch file has it run with no issues. So now I have found another no-no for RSS- don’t run some of it off of a CD, or if you do make sure the current directory is a disk you can write to!
