Some frequencies decode better than others - Unitrunker/DSD+
thegriff
Hillsboro, OR
In the nine months or so I've been messing around with decode of my local P25 system I've noticed what I think to be a transmitter related issue.
That is some frequencies decode better within DSD+ than others. I can get the correction value for my TXCO dongle darn near perfect but ultimately some frequencies within the range just won't decode all that well. Tonight I noticed Unitrunker's new "window value" does increase with some frequencies more than others.
Some examples:
851.61250 decodes well, 852.31250 does not
855.51250 decodes well, 856.36250 does not
I don't know whether there's an acceptable drift for transmitters but it seems the dongle correction is not tuned as well as I think or the transmitter may have an error factor itself.
Assuming the latter, how would I go about fixing this sort of variable drift? I was thinking I could sit down and manually adjust each frequency within UT's interface until I get the actual frequency. For example maybe 852.31250 needs to be adjusted to 852.31000.
With over 20 frequencies in my local system this method would take quite a while so I was wondering if there's a better way to figure out if there is a transmitter issue for certain frequencies and what sort of variances I should add/subtract to make things go quickly.
FWIW, my voice receiver has a TXCO and is 820T2 based. I've also noticed similar issues on my PRO-668 so I don't think it's dongle tuning but I'm no radio tech.
TIA!
Hi Griff;
Run an SDR program like SDR# to span as must of 851 to 854 Mhz as the RTL stick can cover.
Zoom in on some of the channels to see if and how far off they are.
2.5 khz seems like a lot.
