steve-kc7byp
I just picked up a Yeasu ft-101e for $100.00 it may or may not have a power supply problem. The ham that I got the 101e from told me that the radio was working just fine, then wile tuning the finals the main fuse popped. He put a 4 amp fuse in and it popped again. The manual calls for a 5 amp fuse when wired for 117vac. The radio is trying to work on the 5 amp fuse. things start lighting up and there is sound for a split second before the fuse popes again. If I just turn the heaters on with the main power off the fuse does not pop. My gut tells me to post this question before trying it. The book that I downloaded says a 5 amp fuse. Given what the radio is doing. Could the copy of the book that I have be wrong on the size (amp wise) of the fuse? Maby the radio just needs a higher amp fuse, like a 7 or 8 amp fuse
