AlmostHandy
I'm going to try my hand at building an antenna. I've been doing a lot of googling and reading, and have a few questions I can't find (good) answers for. I think a lot of the pages I'm looking at assume that you know some of this basic stuff, so I'm I'm sorry if this is really long and boring, but I'm kind of CDO about giving details.
1. I'd like to start by building an antenna that covers the local Air Frequencies. I've heard the best way to do this is with a vertical dipole. I've found a couple of cheap outdoor baluns for tv sets, and I've read that this makes a good dipole. Is this ideal for the aircraft band, or should I consider a different design?
2. My second question is about a railroad specific antenna. The AAR frequencies are all clustered pretty tight, around 160.xxx, but it's been said that railroads are commonly using other frequencies, notably in the 45x.xxx - 47x.xxx ranges. Is there a dipole design work for both 160.xxx and 460.xxx? It looks like the multiple of 160.xxx is 480.xxx, which isn't too far from that 460mhz. How well will that work? Would using thick copper pipe instead of wire help to widen the bandwidth? (see #4)
3. Does the SWR of the antenna matter if the antenna is receive only?
If so, how should I go about finding an SWR meter? I haven't been able to find any dummies guides to SWR meters, so I have no idea what I'm looking for. Of course, the range of options is incredible. I've seen things like this cheap $15 model, but I know about the "You get what you pay for" way of business, so am wary if it will even work for my applications. What kind of specifications will my SWR meter need to have? Should I be looking for a local ham who will analyze my antennas for a 12 pack and some pleasant conversation instead?
4. I have read that the thickness of the wires is a factor in determining the bandwidth of the element in question. The thicker the wire, the wider section of the band it will receive, correct? How thick can the elements be? For example, when making a dipole, can I use 1/2 copper water pipe instead of wire?
4a. Concerning this Multiband Groundplane Antenna design; Do all three element wires need to be the same thickness? Can I use a thicker wire on the longer, lower band elements for a wider bandwidth, and a thiner wire on the 800mhz element for more specific tuning?
Do the ground plane radials need to be the same thickness as well?
5. And lastly, and this is a bit trivial, but it seems that when I'm done, the ground plane device will be quite lanky, and a little rickety. Besides using a piece of conduit to hold the whole thing up by the connector, (which I'm told must be thoroughly coated with some silicone to keep moisture out), what kind of protection should I use on the radials? Won't the copper corrode after time? Can I use some kind of spray poly coating to protect the wires, like Plasti-coat?
Thank you, everyone!
-Mike
-Mike
