Some PPS settings that are just not clear
minasha
NYC
I have a few questions on some PPS settings I don't understand:
1-In D-5 I am entering a P25 conventional channel since the channel has no TG in the P25CTGID do i leave it "no setting"?
2-In D-6 setting up a zone for this channel do I need to check enable repeater mode? (With DMR channels I do need to check it)
3-For the same P25 conventional channel in D-6 zone setup do I need to put in a NAC code? If I don't know it and I want to get all nacs availlable do i set it
to 0xF7E or FFF or leave it at 0.
Thanks for the help
N6ML
SF Bay / Delta, CA
There's always a TGID. If you don't know what it is, create a wildcard group with P25C TGID of 65535 (decimal)
If it's a repeater (it probably is), check the box.
If you don't know the NAC, 0xF7E will act as a wildcard.
minasha
NYC
For the NAC how can I enter 0xF7E it's in hex it won't accept an x
N6ML
SF Bay / Delta, CA
"Repeater" mode has no meaning in the context of P25
I was wondering what it would actually do, but don't know the P25 protocol(s) enough to say that it doesn't apply. If it doesn't, it's a bit curious that the PPS help specifically mentions P25 Conventional:
minasha
NYC
It says available in conventional P25 thay would be "the context of P25" right?
Webodisk
Mike
Virginia Beach,VA
Tried it on P25 conventional, I did not notice a difference, DMR no receive when not checked if the frequency was a repeater
