LAYMAN
First of all..........new to pro-95, new to RR.Com
(1) I have noticed that while scanning in trunked mode, sometime the talkgroup will display, along with the voice channel, but NO SOUND.
what's this about? Because if the talkgroup is displaying, then this means my scanner is hitting the control channel......anyone else having this problem?????
(2) I have noticed that if i only have one channel in a bank unlocked, and other banks with all channels programmed and unlocked, then the scanner seems to skip over the bank, that has only one channel.
i.e. "bank 1"-O.C.P.D. (All divisions prog., and unlocked), "bank 5"- security bank, all channels prog., only one channel unlocked.
(3) THERE IS BLEEDING ON SOME CHANNELS. i.e. Bethany Fire (i think) 460.600 is bleeding over to some of my Oklahoma County Freq's.
(4) Search mode - the scanner stops at an unspecified freq., i.e.
if searching and stopped at 453.7789, when actual freq., is 453.7875, etc.
(5) it eats your batteries up in no time flat, i have not had a handheld before in my life that ate up my batteries this quick!!!!
(6) EDACS Trunking appears to be not working correctly.
