Someone Please Tell Me what I'm doing wrong with Programming
Sydney472
Talking Rock, GA
Only programmed this PSR 800 a couple of time using EZScan and, unfortunately its' been about 2 monthis since I last messed with it. Problem: I first wanted to install a new county freq in ScanList Control under General Settings under #08 so I clicked on and highlighted the corresponding box next to #08 and "enabled" and also highlighted and checked the box next to enabled which is "default", so both are highlighted. Also under "General Settings" I renamed my scan list "DCSO"
Next I went to Library Import and chose my channels and clicked on Import Channels and made sure that the proper ScanList, again #08, was selected.
Next I went to the tab Conventional Frequencies and see that the channels I just imported are there at the bottom and all the way far right, I see that they show ScanList #08
Lasty, I had my PSR-800 plugged in, and the power was off. I went to the file and chose "Copy Library to Scanner Memory SD Card. I will through all the "downloads" and finally said the Import was compete.
Problem is this new ScanList I created under #08 and titled "DCSO" is not showing up. What am I doing wrong. I did this twice and the same thing, no change can be seen in my scanner. Please Help.
Thanks so much i advance for any help.
