Somerset County Trunked System Programming Question
rbartolu
St Johns, FL
I'm using the Pro-2096 now to monitor the county's trunk system. I think I have it setup correctly but I'm not sure - I'm using Win96. The question I have is that I have both the MOT 3600 CC and the MOT 9600 CC set to "Multi Table" and then in the Extended Tables area I have both the 3600 CC and the 9600 CC set to UHF, and then I have the 4 pairs of Base/Offset/Step below - does the CH Lo and CH Hi settings matter?
robbinsj2
Bridgewater, NJ
Heh, love copy/paste! :)
The Ch Lo and Ch Hi should be provided -- some scanners interpolate
this data but the 96/2096 seems to want it. The custom table should be:
Base=500.3375, Offset=380, Step=25.0, Ch Lo=380, Ch Hi=429
Base=501.9125, Offset=430, Step=25.0, Ch Lo=430, Ch Hi=449
Base=502.5125, Offset=450, Step=25.0, Ch Lo=450, Ch Hi=759
The last config (specifically the Ch Hi=759) may change if/when more
repeaters are added to the system, but it will work fine until then.
Once upon a time I showed a fourth config, but it was only a
placeholder and wouldn't actually do anything until the 47*
frequencies are added (at which point it would probably change anyway).
I haven't been able to monitor live recently, but based on my Trunker
logs it looks like there has been very little activity for the past
few weeks.
Jim
