You are correct- the 700 cell was LE only. However, major headway has been made this year to double the capacity of Site 4 from (5) frequencies and limited TDMA pathways (one frequency was locked to FDMA for Public Safety, another for CW/Protected, etc.), to (10) frequencies boasting up to 20 TDMA pathways. Initially, select Fire Regions (3 & 6) were made accessible to 700 subscribers, but today allows for all county-based traffic that is on the UHF cell in FDMA to be available on the 700 cell converted to TDMA full-time. This also means the County F&S talkgroup, Ranger Main & Ranger Tac, Montgomery DPW, and I would take DPW N and DPW S which all originate in UHF to broadcast voice on 700. With the movement of Franklin Township to the big ASTRO25 from SmartZoneIs this system note no longer valid?
Law Enforcement operates on the 700 cell, Fire/EMS/OEM on the UHF cell
I believe at one point the 700 cell was exclusively LE and the UHF cell exclusively everything else...is that no longer the case?
Specifically, did Fire/EMS/OEM finally migrate to 700, or are well into the process of migrating so that while there may still be Fire/EMS activity on the UHF cell, all of the talkgroups are also now active on 700 full-time?
And what of the public works/schools, are they still on the UHF cell?
Since you mentioned Franklin trs is astro25 i should be able to program a unication g5 and hear franklin fd/ems since they are in the clear? Just have to figure out all the astro25 system settings since RR only has the smartzoneII info.You are correct- the 700 cell was LE only. However, major headway has been made this year to double the capacity of Site 4 from (5) frequencies and limited TDMA pathways (one frequency was locked to FDMA for Public Safety, another for CW/Protected, etc.), to (10) frequencies boasting up to 20 TDMA pathways. Initially, select Fire Regions (3 & 6) were made accessible to 700 subscribers, but today allows for all county-based traffic that is on the UHF cell in FDMA to be available on the 700 cell converted to TDMA full-time. This also means the County F&S talkgroup, Ranger Main & Ranger Tac, Montgomery DPW, and I would take DPW N and DPW S which all originate in UHF to broadcast voice on 700. With the movement of Franklin Township to the big ASTRO25 from SmartZonesoon, you can also find days-worth of Franklin PD Main using up TDMA channels on Site 4. Their Fire & EMS are scarce on 700, but I digress.
While the UHF-originating voice occupies spectrum on Site 4 at 700MHz simultaneously, this does not reflect the actual end-user radios utilizing 700MHz spectrum and taking advantage of this cell's coverage. As far as I am aware, the only municipal non-LE entity that has been granted access to Site 4's 700MHz performance to date is the North Plainfield Fire Department. Any other Fire/EMS/OEM agency whose radios attempt to register or affiliate to Site 4 are denied, even though they may match all the feature criteria to be permitted onto this cell. More fire agencies are migrating toward cutover to 700MHz with the replacement of mobiles and some to all portables in their fleets in comparison to EMS forced to move at snail speed- though, agencies will not get to taste 700MHz on Somerset County until their fleets are near 100% readiness like North Plainfield FD has accomplished.
Although there is a Schools TG, it has a very limited user base of one or two districts that I will leave unnamed- it is not like the Ohio MARCS system where many schools have a Motorola APX mobile with that special O2 head outfitted with a giant emergency button paddle. I take that they are UHF as I have not seen registration check-ins or the like on Site 4 along with 4-digit IDs. As eluded earlier, the municipal DPWs continue to be UHF- County Roads and all that have lived on NJICS for a while.
It will be ASTRO25 soon. However, the changeover date is unknown until the missing site elements are received.Since you mentioned Franklin trs is astro25 i should be able to program a unication g5 and hear franklin fd/ems since they are in the clear? Just have to figure out all the astro25 system settings since RR only has the smartzoneII info.
What does the NJICS Band Plan in the G5 on that Site have to do with Somerset County and Franklin Twp ? Two completely different systems.Bandplan? Not in the G5. NJICS Miller Lane #28 has its not been transmitting
one for six months so. My G5 and Uniden stuff all deaf as a result.
I suspect we will have to wait to see what the new system elements are.
Program the 700 cell, you'll have much better performance than UHF, and hear more things like law enforcement.I'm planning a trip down there for christmas tomorrow and programming my G5. My question is will i hear anything on the 700 mhz side or am i programing it for no reason?
