Sorry for not posting update info. :>{
D
ddemers8678
Guest
We took a quick holiday and after that, I upgraded my puter and server.
NHSP digital scanner is up and running using Vista 64 bit WME.
TonyMaseli
Where is the Scanner Located? What is in it? I see some stuff right now but I can't get any volume. Just the display. I have the Volume all the way up and other feeds are running ok.
I am up in NH often and like the sites from the areas I go.
Whatever did happen with that shooting? Channel-9 isn't an option here (unless I go on line).
Tony
D
ddemers8678
Guest
I was tweaking, you should have audio now. Scanner is in central NH
One brother shot the other in the back while "unloading his gun" in the car.
regards,
NYRHKY94
Brunswick County, NC
Nice job on the updated site. I like the scanner LCD your displaying now. I'm assuming that is being done via Windows Media Encoder?
doabbs
Milton, NH
Do you have Troop A programmed in there? If so are you able to hear them from your location?
D
ddemers8678
Guest
I do monitor Troop A. Problem is, I utilize twin yagi's and have them aimed more toward the north and west in order to receive Troop B,C D,E, and F as my priority. This also allows me to broadcast Concord, Weare, Goffstown, Fish & Game and all SO. So,,,,,,,, anything easterly suffers. IE: Troop A.
In the following months, I will most likely install another antenna to the east.
Regards,
D
ddemers8678
Guest
Scanner is always down during the day on Mon, Tues, Wed. Doesn't come up till I get home around 5:00 or so and shut down when I retire for the night. (Exceptions: storms, major incidents)
From Wed. afternoon till Sun. night, it is continuous.
Regards,
