Hi Folks,
Has anyone out there ever seen a walk-thur for programing radios? Obviously it would have to be model specific but I was just wondering??
I guess you could clone it if you knew someone in your area with the same set but is there a general walk - thru or how-to procedure for stuff like that?
Of course in my case, I'm a newbie who just got a FT-2900R and I do have the manual. But has anyone ever seen a posting like: " Here's the best steps or a recommended way to program a channel or repeater in to a 2900R"
I get that you enter the freq, save it to a memory, add the offset, etc ....
I found this so it might be an example:
Setting Up A Repeater Channels on Wouxun KG‐UVD1P
Manually Programming an FM VHF/UHF Repeater Channel
a. If keypad locked, then unlock MENU 14
MENU-14-MENU- ↑ or ↓ (“ON” or “OFF”) –MENU-EXIT
b. Change to “Frequency” Mode (VFO) MENU 21
MENU-21-MENU- ↑ or ↓ [FREQ] –MENU-EXIT
c. Enter the frequency via the keypad
e.g. 1-4-6-9-5-0
d. Setting offset frequency MENU 23
MENU-23-MENU- ↑ or ↓ [choose value e.g. 0.600] –MENU-EXIT
e. Setting offset direction MENU 24
MENU-24-MENU- ↑ or ↓ [choose ‘+’ or ‘-‘ or ‘OFF’] –MENU-EXIT
f. Setting sub-audible CTCSS tones for controlled access
i. Receive RX / Decode MENU 15
MENU-15-MENU- ↑ or ↓ [choose “numerical value e.g. 110.9” or ‘OFF’] –MENU-EXIT
ii. Transmit TX / Encode MENU 16
MENU-16-MENU- ↑ or ↓ [choose “numerical value e.g. 110.9” or ‘OFF’] –MENU-EXIT
g. Set high / low power level MENU 4
MENU-4-MENU- ↑ or ↓ [choose “HIGH” or ‘LOW’] –MENU-EXIT
h. Set band width MENU 8
MENU-8-MENU- ↑ or ↓ [choose “WIDE” or ‘NARR’] –MENU-EXIT
i. Set scan inclusion / exclusion MENU 13 (Busy Channel Lockout)
MENU-13-MENU- ↑ or ↓ [choose “ON” or ‘OFF’] –MENU-EXIT
j. Save to a channel MENU 27
MENU-27-MENU- ↑ or ↓ [choose “channel number”] –MENU-EXIT
Or
MENU-27-MENU-[enter channel number on keypad]-MENU-EXIT
k. Deleting an existing channel MENU 28
MENU-28-MENU- ↑ or ↓ [choose “channel number”] –MENU-EXIT
Or
MENU-28-MENU-[enter channel number on keypad]-MENU-EXIT
l. Name the channel and save the name MENU 26 A-Z, 0-9 ; max 6 characters
Change to “Channel / Name” mode MENU 21
MENU-21-MENU- ↑ or ↓ [NAME] –MENU-EXIT
MENU-26-MENU-
[Sequentially enter ↑ to select a character]
[enter ↓ to save and go to next character]-MENU-EXIT
m. Change to desired display mode (Freq, Chan, Chan/Freq, Chan/Name ) MENU 21
i. FREQ “Frequency only” i.e. 146.950
ii. CH “Channel Number only” i.e. CH-021
iii. CHFREQ “Frequency and Channel Number” i.e. 146.950 21
iv. NAME “Channel Name and Channel Number” i.e. VE6XXX 21
n. Lock keypad MENU 14
MENU-14-MENU- ↑ or ↓ (select “OFF”) –MENU-EXIT
See !! I mean that posting is pretty sweet and everything is there so it's kind of handy ....
Are there other places or people out there who have done the same thing but for different radios?
Cheers'
Dave
e.g. 1-4-6-9-5-0
Or
Or
MENU-26-MENU-
Cheers'
Dave
