Sorting Lists to Monitor
N1GTL
CT
Is there a way to sort the favorites list in Sentinel, Butel or ProScan so, when I enter the "Select Lists to Monitor" screen on the scanner, it is sorted numerically or alphabetically?
dave3825
Suffolk County NY
Yes. In Sentinel, I have mine arranged/sorted by quick key (ascending) . I also label my fav lists with the quick key in the label so sorting alphabetically works for me also. Pretty sure @ProScan can do the same and would imagine Butel also.
werinshades
Chicago , IL
In Sentinel...Edit tab...Sort Favorite Lists. Once any changes made, x out and you'll be prompted to Save. Once you do, it will change in left column.
File...Save.
The Write to Scanner, Erase Favorite Lists in Scanner, and this will change the order on the scanner itself.
Chris0516
Pittsboro, North Carolina
I have never used Butel, but. I do have ProScan n' Sentinel(for Firmware and HPDB updates).
In ProScan, I can sort, by TGID, by Frequency, by Tone, by RSSI, by UID, by Mod., by Hits, by Duration, by Start Date/Time, by End Date/Time, by System/Site, by Department, by Channel, by System Type, by Digital Status, by Service Type.
Ubbe
Stockholm, Sweden
In ProScan
He ment sort the different favorite lists, not what's inside a favorite list.
"when I enter the "Select Lists to Monitor" screen on the scanner, it is sorted numerically or alphabetically?"
In Sentinel main screen you select Edit and Sort Favorite Lists. Then it can do an alphabetical sort and/or you mark one or several lists, hold down Ctrl to select several, and click on the green up or down arrow to move them.
/Ubbe
ProScan
Software Provider
Ontario, Calif.
In ProScan, you can either drag the Favorites nodes to where you want them or use the Utilities menu Sort and sort the Favorites nodes there. Write to the scanner afterwards.
ProScan
Software Provider
Ontario, Calif.
That's the History Log. The OP is asking about the FL.
N1GTL
CT
Thank you RR Community! I used Sentinel and it worked perfectly.
I do exactly this! It's so helpful when you can't remember the FL numbers.
dave3825
Suffolk County NY
I do it on fav lists as well as systems and sites. Very useful when you have a lot of stuff.
N1GTL
CT
I have not figured out how to easily enable and disable sites. If you do that with quick keys, I'd love to hear how.
ofd8001
Louisville, KY
It's like tying knots. A little challenging at first, but once you've done it a few times, you don't give it much thought. Here is how:
Site Quick Keys are at the "Department Level". So generally, it would be better to not use the same number for a Site Quick Key as you would for a Department Quick Key. (But there are exceptions to that rule.)
So let's say you have a Favorites List with a Favorites List Quick Key of 1. In that Favorites List you have a System with a System Quick Key of 2. Then within that System (which is within the Favorites List), you have three sites using 61, 62 and 63 as Site Quick Keys.
If you want to toggle the Site with the 61 Quick Key, your key press sequence would be 1.2.61 eYes. (You have to be scanning - if you have held either System/Department/Channel, the scanner will think you are doing a different operation - a Number Tag.) Also, you have to be careful to not turn off all the Site Quick Keys at the same time or you'll get the "Nothing to Scan" message. And the periods are important separators so the scanner doesn't get confused.
Ubbe
Stockholm, Sweden
Also if the scan cycle are in that FL you can skip the 1 but keep the dot and do .2.61.E
And if you already are in that system, perhaps you have made a Hold on it, then only the last digits are necessary ..61.E
/Ubbe
N1GTL
CT
Thanks. I'll give this a try this week. When I am home, I use a single control channel that is on our state system that I receive great. I'm also at a spot where three state police troops sort of meet so I use that single control channel. I'd like to learn how to enable and disable sites easily so when I'm working on the road, all that time isn't spent scanning control channels that are not in range.
/Ubbe
Great info on using the dot. Thanks.
radiochuck
Traffic Reporter
Phoenix, AZ
A GPS receiver connected to your scanner can change your life. Believe me.
I could never go back to the old way.
dave3825
Suffolk County NY
Gps is the simplest way as once set up, you really don't have to do anything. If gps is not an option, departments and sites use the same quick key ( 0 - 99). Luckily the systems by me do not really have a ton of departments so on systems with less than 10 sites, I qk them 90 thru 99. I also include the sites qk in the alpha tag. For systems with 10 or more sites, I start at 80. Unfortunately for some people, there are more than 100 departments on some systems leaving no available quick keys for sites. In that case, I only number departments of interest and set all the rest to avoid and do not use qk on those.
radiochuck
Traffic Reporter
Phoenix, AZ
Truth! I love that I can just let the scanner do the work while I'm driving and I don't have to fiddle with any of it.
I'm usually using faves lists that I've setup using rectangles instead of the circles (I still use circles for towers/sites) offered by the full database. I have things about as precise as I can get them, without making it my life's work, and it has been well worth the effort.
It's been a lot of fun to work with setting up the coordinates and then seeing them in action as I drive between areas. It would be great to someday be able to import data from sites like arcgis and not be so tied to the rectangles, but that may be asking a lot of the scanner.
It has been well worth whatever I paid for the GPS receiver. About $80, I think.
Ensnared
Waco, Texas
I hate my GPS and never ever use it. Usually, I program trips I take. If I don't have time, I use the zip code method.
When I make a Favorite, I put the FL quick key & FL number tag in front so that I can see it when I go to the menu "Set scan selection", which opens up to "Select lists to monitor." Example: [29] Federal
That is they way I roll.
You can sort all of the Favorites under "edit" at the top of the Sentinel software.
