Source Code for ESK Etrunker version.
Does anyone know where I can get the Source Code for the 'ESK' version of Etrunker ?
It would be appreciated ..
I have the source code for 3.8.3 .. but I am looking for the source for the ESK portion.
I would like to get the source of the ESK .exe if possible .. then I can compare the 2 versions.
I tried to find what I am looking for on RR here .. but couldn't find what I wanted. I will try again ... as I recall that Lindsay was the one that figured out what needed to be changed.
I believe it is just a few lines of code that needs to be changed, but I don't know what it all entails.
It's a two line code change. This is ancient history ...
Look in the vicinity of line 485 of EDACS.cpp. Specifically, replace:
info.cmd = orf;
... with ...
info.cmd = orf ^ 0xA0;
newRaw ^= 0xA0;
For most folks, the worst part (due to lack of familiarity) is dealing with the quirks of Watcom to build a protected mode DOS program.
Thank you ... it is appreciated. I knew it was someplace here in RR, but I couldn't find it. There are obviously a lot of hits for ESK here at RR.
