Source for BNC antenna chassis mount?
fredg
East Central Kansas
I need a replacement BNC mount for my Radio Shack Pro-83 handheld scanner.
The first picture on the left is what the old one looks like that I removed just now.
I can find a bunch like in the right picture, but as you can see, the threads are below the plate while the one I removed has the threads above the plate.
Any ideas where I can get one? Or does anyone think the other style would work as a replacement?
mitbr
Tampa Bay Florida
You need a rear mount bnc bulkhead the picture to the right is a front mount the one from your radio is a rear mount.
Tim
fredg
East Central Kansas
Tim
Thanks Tim! Not much luck finding one.... it appears that the front mount is the most common.
I think I could make the front mount work and they are only a few bucks on eBay.
mitbr
Tampa Bay Florida
Your welcome and that is not true they are both equally available try mouser or allied web sites or google rear mount bnc bulkhead.
Tim
wkm
WA
I bought one at Fry's a year ago. It's the bolts from the rear but has longer threading than the one pictured. It a Pan Pacific product.
fredg
East Central Kansas
Tim
Yeah did that... couldn't find one that looked the same on Mouser... and Googled for rear mount as well... just not seeing anything close to the same, one thing a Google search found was: BNC Bulkhead Rear Mount | Allied Electronics, Inc
None of those look like they are the same.
This is a old well beat scanner, even if I have to mod things a bit to make it work I am thinking one of these:
BNC Female Bulkhead Mount RF Radio Connector USA Seller | eBay
or
BNC Female Bulkhead Mount Connector by W5SWL ® | eBay
Can anyone tell me what is different between the two eBay jacks linked above?
They look slightly different, but the specs don't hint as to what is different about them..
I am leaning to the second one as the nut appears to be more flush to the ring and might fit better.
R
retiredmich
Guest
Try this place
G&G COMMUNICATIONS Gerry Oliver - Owner 7825 Black Street Rd., LeRoy, N.Y. 14482 Phone: 585-768-8151
teufler
ST PETERS, MISSOURI
they look one in the same. The stem looks like it will fit alittle longer in the case but if you have the room, in the case, you should be good to go,
fredg
East Central Kansas
I went with this one:
Like I said this scanner is old and beat but still works fine so I am not opposed to using the Dremel tool and epoxy to get it to work in the case. :)
Thanks for the help!
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Threads merged. Please don't ask the same question in more than one thread. Thanks.
